My kubota will start but acts like it is missing and then eventually will die. When it is starting it will blow a lot of black smoke at first and this was when it was 60 degrees outside.
Here is what I have done.
Bleed the fuel filter housing, injection pump, and injectors. I followed the videos that Vic had on youtube.
I also took the feed line to the fuel pump off and turned the pump on just to make sure I was getting adequate fuel. This was before I did all the bleeding.
After this I am still having the same issue. I then checked the oil and noticed it was about one inch over the full mark, and looked really runny and black.
What else could I check? Is there a way to test the fuel injectors?
Thanks
Thanks
