I would think the location of the float function should be verified before turning the joystick around.
Of course that is true! But I'm almost positive he will find the "float" position is back as he now has it installed. This is not an uncommon condition when customers install their own loaders.I would think the location of the float function should be verified before turning the joystick around.
Is this an OEM replacement valve? If so it has a regenerative dump circuit and most likely you have the hoses going to the cylinders reversed.I have the exact same problem on my loader. Installed new valve assembly have made sure all lines are correct. Still the bucket only dumps. If i hold the roll back just slightly over the bucket will creep back but will not fully roll back. takes for ever. My thoughts are a broken piston or seals. but just really weird. Did this feed ever get resolved?
Say what?switching at the valve just makes it regen (both ports pressurized) when you try and curl. which makes it dump in both directions.
I would switch the connections between the hose that comes from the valve and the hardline on the loader. not from the hardline to the cylinder.
i can't say your connections are the same as my b2100 ?, but !!..i did have this issue with my bucket not curling once i had all the lines connected. my problem was the bucket was not working correctly when using the joy stick ?, come to find out..i had the two lines coming from the hydro line that leads from pump to rear hydro area backwards ?!. once i swapped these two lines around, now everything works correctly !. sooo...where ever your joy stick gets its hydraulic fluid from ?, check to make sure you have those lines in the correct spot coming off the line ?!. this pic clearly shows the correct routing of the lines to joy stick, i had the two lines backwards from the diverter block, swapped them, everything works great now.could anyone possibly post a picture of the proper position of the control mechanism on the joy stick. Not totally sure I have it in the right position and the manual is no help on how its installed.
Thanks
DJ
Is this correct position for the remote. Front cable is for the boom up and down. It works correctly except for the float. Pull back boom goes up. And thank you for all the suggestions so far.
Your latest issue sounds more like a cable control issue than hydraulic. Have a helper operate the joystick while you watch the movement of the spool in the valve.I made some headway today. Got the roll back issue taken care of. Some of you were right. The hosing was backwards and had to change the position of the remote connector block.
So now a different issue, when raising the boom, if I have any rpma to the motor and I'm full back on the stick, the boom will lock up mid lift. I have to drop it slightly. If I pull back gently, not much force, the boom raises just fine.
Any thoughts on this one. I would still like a picture of someones remote station to see if I'm in the right location.
Problem found and remedied. The quick coupler had a miss matches set. One side of the couplers plunger would close the plunger and the system locked up. Replace couplers and all is good I'm the world.Your latest issue sounds more like a cable control issue than hydraulic. Have a helper operate the joystick while you watch the movement of the spool in the valve.
