Gravel on grass?
mike paulson
229
25
ulster, NY
what are you guys out there doing to get your gravel driveways off your lawns and back on the driveway, after a winter like the one we just had where I pretty much plowed my entire drive onto my grass.
2,594
I using my bucket to pick that white sheeat up and dropped a bit of gravel in the yard, cussed like hell,
I hand picked up about 3 five gallon buckets worth about 3 weeks ago.....
aint no easy answer, landscape rake maybe. Back drag the bucket.....
bubst
L3200, FEL, pallet forks, box scraper
Jul 14, 2013
Minong, Wi
bubst
Today, 09:59 PM
This is a good question. What I started doing as the snow started melting is picked through the pile of snow and gravel with my bucket. I the dumped the snow and gravel mix on my driveway. The snow melts and some of the gravel is back on the driveway. Not all of it mind you. This also gives me another reason to use my tractor.
Bubst
6,808
Look into getting a pine needle, or a straw rake.
gpreuss
Oct 9, 2011
1,166
Spokane, WA
A landscape rake does a pretty good job. Go pretty slow.
OldMasterTech
KX057-4, KX121-3, L4630GST, RTV1100, AT60, T1700, T1560, 555E
Mar 28, 2011
30
Massachusetts
Stihl br600 backpack blower - it's almost too easy! I blow all the gravel from the lawn into a windrow in the center of the driveway then regrade it.
olthumpa
L275
May 25, 2011
1,501
Maine
gssixgun
L3600, FEL, SnoBlower, Box Blade, Rear Blade, Forks, Cultivator, Plow
Jan 5, 2013
257
47
Sandpoint ID
www.gemstarcustoms.com
bubst
Today, 09:59 PM
Bubst
Yeppers I tried the same thing this year, it actually worked pretty good, I used the Back Scrape Blade and went around the edges and took the foot or so of snow/rock from the grass and moved it onto the driveway... Ended up doing pretty well only doing about 1/4 of the handpicking this year,,,
3,475
I just run the roller over the edge of the yard by the drive way when its really wet pushes the gravel in the mud and order a load of 2a modified up tail gate it drag it out and its all good
