Most of the ballast systems I've seen are too large for the bx. It is very low to the ground. This is a gas water heater. I cut one end off, then removed the correct amount to give me the right spaceing for the quick hitch. Welded the end back on, welded a bar thru the center, added the correct sleeves to fit the quick hitch and added the top bar. The water fill holes are where I added 80 lbs of sand and then about 10 gallons of antifreeze and water. I'm guessing the whole thing weighs around 200 lbs. I used to keep the box blade on the back but I was always hitting something with it when I turned.
