Carhartfarm, I'll mention it one more time. Before you ASSUME that its a complicated and expensive fix, have you checked my suggestion?
The LIKELYHOOD of jumping teeth on steel gears is FAR less likely than contaminated fuel. The LIKELYHOOD of a sudden loss of compression or whatever on a Kubota is far less likely than contaminated fuel.
Have you checked the fuel? It may not smell drastically different since the new stuff doesn't have much sulphur in it. I'm not sure the exact way to determine besides a simple draining of your fuel tank and bleeding all your lines with fresh diesel from a truck stop or reliable location.
Just a polite suggestion. I hate to see people ripping down motors that are very likely NOT broken.
