It is surely cheaper to buy the FEL with the Skid Steer stuff up front. My quote was for a conversion... which is pretty pricey. I'm thinking that an an independent welder would do the job for less than the dealer.
I think you would be better off hiring a local werder. It will not only probably cost you less but you will also be able to have this built exactly how you want it.It is surely cheaper to buy the FEL with the Skid Steer stuff up front. My quote was for a conversion... which is pretty pricey. I'm thinking that an an independent welder would do the job for less than the dealer.
I put a picture in the gallery of the quick attach system that I was telling you about. If you will go to my album page I have put in several pics including the part number that is for my LA 450 S loader. I have had really good luck with this setup. I can go from bucket to forks in just a couple of minutes with no problem at all. I think it's a more dependable system than the skid steer type. As long as the pins have a little lube on them there is nothing to wear out from use. It has no moving parts that are not already greased with normal PM. If I can help in any other way just let me no.Yeah, I'd like to see that. Thanks!
Welcome back Paul!Man oh man you guys give me WAY to much credit. Anyway I do appreciate the kind words here I really do.
I never left. Just stepped out for awhile. Kind of like going into hiding If I'm not posting I'm either away or busy and in this case it was both. Great to come back though and see you guys are still posting away. Thanks again. PaulWelcome back Paul!
You are the miracle man and credit is given where credit is deserved
Scott
If you are coming to disney world bring it with you. I live 30 min from there. Ill weld it for you.At this point, I'm leaning toward installing the skid steer adapter on my loader and finding a used bucket or having a plate welded to my existing bucket. I'm thinking I can do everything but the welding myself (whenever I weld it looks like a bird dumped on the thing--I'm not going to subject my tractor to that!).
I've got a couple weeks to figure this stuff out as we are outta here to Disney World in a few days.
