2013 L3200 HST fuel bowl guard
Dad03
L3200HST
Sep 17, 2011
34
Columbia, TN
Just got a new L3200. Was out working the box blade and moving some tree cuttings playing with the FEL. Parked it in the driveway. Came back about 45 minutes later and noticed a fast drip of diesel coming from the fuel bowl area. It did not look damaged. I decided to unscrew it to check the gasket. I noticed while unscrewing it the threads were not balanced. Could not find a fuel cut-off so made a even bigger mess. Did not see any issues so I put it back on. it went back on straight and was not leaking after that.
I used it breifly the day before with no issue.
All I can figure is something hit the clear bowl and knocked it off thread (if thats possible to do without damaging it)
It is kind of vulnerable just sitting there with no guard. Is there any kind of guard for these?
Benhameen
2012 Kubota L3800 HST W/FEL and 1963 JD 2010 row crop utility
Jan 27, 2013
707
128
Southern IL.
I broke the fuel filter body while brush cutting. There's a thread in here about it somewhere. I had planned to build some type protective cage for it but never did. Please post some pics if either of you decide to make one.
BotaDriver
L3800dt
May 15, 2013
326
North GA
I use an extra large oil filter as protection. I have 60hrs or more tearing our brush and trees that would make most people cringe. Nasty stuff, and not a single issue. You have to watch out what you're doing as there is many other things to damage besides the fuel bowl. I have had to use a sawsall to remove sticks from various parts of the engine. Hasn't been an issue since I've made it a point to never be in a position to allow the spears to contact the machine.
Vt. Bear
L3800HST,Loader.Backhoe,Landpride grapple bucket, Countyline tiller
Mar 22, 2014
Belmont Vt,USA
Look on Ebay under Kubota L3200 and you will find a cleaver guy in Vermont who makes and sells a guard for the fuel filter. I installed one on my 3800. Very easy to do.
78-79fordman
2013 m7040hd 2013 L3800HST 1969 MF135
May 21, 2013
255
Gillham Ar.
Ya I guess that little shield is better than nothing .
But after to day I'm building a shield to cover a little more area . Had something kink the line going in the filter housing . We thought it was out of fuel put more fuel in still wouldn't start . Then got to looking and it was kinked .
Dad03
L3200HST
Sep 17, 2011
34
Columbia, TN
I ordered that one on eBay. It appears to be a pretty nice piece. Went on easy. I guess if this does not provide enough protection I am pushing it to deep in to the sticks.
