On a kubota L2800 hst 4x4   So  far I have changed the fuel filter bleed the injector lines using the bleeder and doing it  as decribed in the book by opening the bleeder and then starting the engine for thirty seconds and shutting down the engine and closing the bleeder. I have also bleed the injectors one by one while the engine is running and got a good stream of fuel from each injector.
The engine wants to stall when engaging the hst but not when you put a load on it with the hydrolics.
Any help would be appreciated. Andy
