pto protection
tonyvkubota
2013/B3200HST/L504 loader/60" rotary finish mower/ 60"brush hog
Dec 14, 2013
72
ny
For a new ( 2013 ) B3200 when brush hogging would I need the over run protector ( not sure that correct name/ term ) placed on my rear PTO to prevent damage to PTO shaft if I hit a large rock ? Or is there an internal slip protection system ?
The_Al
L3540, Heavy duty FEL, 9' bachoe, Brush hog, 72" grappler
Jul 19, 2013
154
MA
It may vary by the brush hog, but a brush-hog slip version is what I think you are looking for. That is what I have, and it works pretty well versus a lynch-pins version.
Some others may have better details.
HTH
beckmurph
Kubota LX2610TLB/Woods finish mower/woods rotary cutter/
Aug 23, 2012
332
325
catlettsburg, ky
Your brush cutter should have either a shear bolt or slip clutch. Maybe both. My LandPride brush cutter had a shear pin/bolt. My Woods has both a shear bolt and slip clutch.
I believe that an overrun clutch is for older tractors.:)
tonyvkubota
Dec 14, 2013
72
ny
I am sure the brush hog has no overrun on it. Its a old unit, I will look closer to see if I can see a shear pin/bolt. I knew of someone who cracked the tractors PTO/crankshaft when he hit a large rock. He just kept saying if I put a overrun slip coupler on my tractors PTO I still be brush hogging....... instead of repairing.
But I thought I read new tractors have an internal slip system to prevent damage in such scenarios. Thanks to all taking time to write. This forum is as much fun as using my tractor. ( OK....almost )
beckmurph
Aug 23, 2012
332
325
catlettsburg, ky
I am probably in over my head here, but:
Could you put a slip clutch on the pto shaft at the gear box on cutter.
If you don't have some sort of protection for your pto, a rock, stump or other obstruction will break something expensive internal.:eek:
Donystoy
Dec 10, 2013
738
380
Binbrook, Ontario
I have hit a ton of rocks etc. with mine over the years and other than creating a lot of dings on the inside and dulling the blades I have done no other damage to mine. The blades are on pivots and just bounce off of objects and swing out of the way. Mine is a JD and has a shear pin where the pto shaft attaches to the gear box. I have never had to change it.
tonyvkubota
Dec 14, 2013
72
ny
Well you are on track with your thought about protecting the PTO shaft from a sudden forced/jammed stopped. But the location for the protection is by putting the overrun coupler on the tractors PTO, this way all implaments just connect to the coupler. That way one is not needed for each implement. I seen them on old Ford 9n tractors. But I was being told new tractors have a internal slip protection system. I like to get this confirmed. Thanks for replying.
tonyvkubota
Dec 14, 2013
72
ny
Thanks for replying and sharing your experience. With my old Ford 9n I did stale it from hitting stumps etc. But never broke anything . Probally because from what you are pointing out.
turck
m5140, JD2020, ford 850, farmal 240
Apr 20, 2013
56
carthage, ny usa
was told by the dealer that there is internal protection on the newer tractors so no external overrun clutch is necessary. A slip clutch basically replaces the shear pin kinda sorta.
TripleR
Sep 16, 2011
1,911
9
38
SE Missouri
It "seems" some are confusing an over running clutch with a slip clutch.
http://www.tractordata.com/articles/technical/pto.html
While older tractors often needed an external slip clutch, we have them on ours and you can get an external slip clutch to mount on the tractor PTO, I've never heard of an internal slip clutch. A slip clutch requires regular adjustment and it would seem to be prohibitively expensive to design a wet, internal slip clutch.
I'm not saying they don't exist, I've just never seen or heard of one on machines in common use.
In Utopia
L175 FEL
Apr 21, 2013
669
201
Utopia,Tx/Pasadena,TX
Speaking as some what of an expert on resizing rocks I can tell you the blades fold back and rock shards fly everywhere. Heck, at one time I thought about wearing some catchers shin guards on backwards to keep the pieces off the back of my legs.
I added an overrunning clutch on my 640 Ford to keep me from plowing through a fence again when trying to stop. In the older tractors, the shredder spinning will keep the tractor moving. With the overrunning clutch the shredder is free to spin, but will not keep the tractor moving because of the ratchet effect.
tonyvkubota
Dec 14, 2013
72
ny
O yeah, I did all you did with five foot brush hog cutter on the old ford 9n, dam there are lots smaller rocks on my place now lol...... And I had it push me along when I was I neutral, learned real quick make sure I had safe path to go with that dam thing. And I manage to stal it when I did not see that dam tree stump. Well with the price of my new B3200 cannot let that stuff happen. Thanks for taking time to reply. TONY
tonyvkubota
Dec 14, 2013
72
ny
I'm not saying they don't exist, I've just never seen or oheard of one on machines in common use.
I am getting some input there is a internal protection system to protect the tractor PTO shaft from sudden stop . I will be researching more. I will let you know what I find. Thank you for taking time to reply.
TripleR
Sep 16, 2011
1,911
9
38
SE Missouri
There may well be, but I don't think it is an over running or slip clutch though the newer ones have over running it's a different thing. I will be interested in what you find.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
80
Rocky Face, Georgia
I believe the purpose of a over run clutch and slip clutch are confusing you. Over run clutch does nothing but stops a pto driven implement from pushing a older model tractor that doesn't have independant or live pto.
A slip clutch goes on the implement and will allow the pto shaft to slip if the cutter hits something solid.
tonyvkubota
Dec 14, 2013
72
ny
OK, thats clearing things up. Is it possible there is an internal slip. clutch to protect the tractors PTO shaft if a solid object is hit ? Thanks for the help .
11,215
An overrun clutch allows for the PTO to slow without slowing the implement or damaging the PTO.
With the tractor off and the PTO engaged try and twist the PTO on your tractor it should slip or click in one direction.
An overrun saves abuse to the tractors PTO from a sudden shut off of the PTO from the tractor side.
A slip clutch or shear pin will protect the PTO in the tractor from sudden stopping / binding / heavy lag of an implement.
Shear pins are great for sudden obstructions, and slip clutches are better for over loading.
