Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
There are just some things that are not covered in a WSM or operator's manual that we stumble upon that make good sense in prolonging the life of our tractors.
Now there may already be a thread that I have not uncovered yet that covers this.... so if there is please feel free to redirect me. Any way these tips should be shared for the benefit of us all and our respective pocket books.
I have one very good one to start the thread off and I have to say up front it is not original by me.... I can't for the life of me remember where I heard or read it.
Preventative maintenance on a Kubota FEL/Front Blade Husco Hydraulic Control Valve; lubrication on the lower end of the spools.
When I was working on my Husco valve I noticed some fairly signifigant corrosion when I removed the spool covers from the lower end of the valve body. It was obvious water had made its way into both the lift/lower/float and bucket roll/regeneration centering springs. Hydraulic oil NEVER sees that part of the control valve. My tractor is garage kept and only gets wet when I get wet operating it... and that ain't very often and water still got in.
Here is the tip to prevent corrosion damage... I drilled 2 holes in both cast spool covers one near the base and the other underneath at the end of the cover. What I do is shoot a little WD40 in the upper hole periodically when I grease the tractor. Also, when I do an oil change I shoot WD40 in the lower hole untill it comes out the upper hole. This makes certain the detent sleeve (1), springs(2), and ball bearings(5) are lubricated prerventing costly corrosion.
Just one note.... when you take the two allen hex head screws off to remove the cap for the first time you can bet the detent sleeve is going to come off with it.... that is what the bearings ride against locking the float/regeneration. This is a sure sign of corrosion.
Catch the bearings in yourt hand or better yet have a rag in your hand to assist in the catch.
I did mine with out taking the valve off the tractor and leaving the three lines attached to the valve hooked up.
This whole process takes only about 30-45 minutes.... providing it is before O-beer:thirty
Butch
Butch
