Hi Logan,My down position is intermittent, the float works but I am increasingly using it for down ???
Logan, I'll take a picture of mine and post it a little later today.(Is this behavior only limited to lowering the FEL)
Yes just lowering the bucket. Where is the spool you are referring to?
Thanks Dusty! Sometimes I need to be reeled back in and advise to start at basic stuff. You the man!Hi Logan. I have an after market loader control on my B8200 and it was doing some thing the same as yours. It had three allen screws that went through the bottom of the joy stick to the control. Two of the allen screws were loose. Good luck & keep us posted.Dusty
Thanks for stepping in Butch. If anybody has these things down pat, it's you! I still think it's really cool you have an X-ray of your valveLogan... any chance you could post a pic of your control valve? If it is a Kubota/Husco I may be able to help. I just went through a repair on mine.
There is not much to the valve, however if it is the Husco there are a couple of things that you may be able to do to fix the issue. Chech the following link to see if this is your valve...
http://www.huscointl.com/media/pdf/construction/9210.pdf
Butch
PS... ther is not much info out there on these valves so I had to do a LOT of research just to trouble shoot mine...
I will check it tomorrow Thanks for the replies.Logan... any chance you could post a pic of your control valve? If it is a Kubota/Husco I may be able to help. I just went through a repair on mine.
Butch
logan, don't get depressed about your tractor. There's lots of great people here with knowledge to get you through this.I will check it tomorrow Thanks for the replies.
not depressed just running out of time for now as an impending road trip is on me. NEW ISSUE.logan, don't get depressed about your tractor. There's lots of great people here with knowledge to get you through this.
Like brother Butch, he's got these remotes to where he can tear them down and put back together in his sleep.
If you can, please take a picture of the remote assembly and post it.
Thank you,
Scott
I don't think you are being unreasonable at all. That is a lot of money to anybody. I would be just as upset as you are.For almost $600.00 I feel there should be no issues. It's a tractor bucket not a space ship. Am I being unreasonable ??
how do I get the plastic cover off?Logan... any chance you could post a pic of your control valve? If it is a Kubota/Husco I may be able to help. I just went through a repair on mine.
Butch
