Seeing the damage in the photo, what you just posted above makes perfect sense. As BotaDriver posted, what function was being performed when the damage happened each time.I just read the article below and it lead to the next question : Locking the differential and turning could lead to a damage like the one i'm talking about?
When to Use the Differential Lock
Because the differential system on your Kubota allows the rear tires to turn at different speeds, locking the differential should only be used when traveling in a straight line. If you lock the differential and then attempt to turn, you put extra strain on the differential lock, possibly leading to its or another component’s failure.
Not just play in the bearings to be concerned with, but anything on the backside of the shaft that would allow any type of play in it. The first time it happened the missing chunk could have came back through the gears and caused enough play that the last 2 times that it's happened, is due to damage from the first time.I think Ismurphy is on to it. You said you replaced the bearing on the axle shaft with the large gear. Did you check for any play in the bearings on the shaft that comes out of the differential housing with the little gear attached?
If there is any play in the bearing the gear teeth will climb each other and all the pressure is on the tips of the gear teeth. That is what breaks them off. They need to run with full side contact.
We haven't change bearing 090 , the one inside the differencial housing , do you think this could be the problem?
Tried to go back and read the entire thread to verify this but I was wondering if the two gears were not replaced as a set you could just be experiencing the effect of having the original pinion wear not meshing correctly with the new bull gear. It is always recommended that when changing out a broken gear that the mating gear be also replaced. The mating surface contact area is then verified by spraying a paint onto the gears and then spinning by hand. I use to use what they called blueing to verify proper center mating contact of gears.
I am very well aware that this is not a differential and there is no adjustment but if the OP finds no other reasons (sloppy bearings etc.) for this obvious improper contact area on the teeth I am only suggesting other possible areas to explore. I would never install a new gear against an existing worn one without checking to make certain of the contact area. There is nothing to guarantee that the original gears wore evenly.He's not setting up a differential, there is no adjustment.
They either mesh or they don't.
Yeah, hard on the diff lock, but it's only ever needed on the soft stuff. I turn and get un-stuck w/ it several times a week.I turn with the diff lock on.
If true then we all would be breaking teeth all the time......on the left side and right side.
