Grapples Grapples Grapples
78-79fordman
2013 m7040hd 2013 L3800HST 1969 MF135
May 21, 2013
255
Gillham Ar.
Ok still a year going here and trying to decide which dang grapple why does there have to be so made different ones .
Started thinking I wanted the Titan 72" weigh'n at 700 pounds . But have about decided that it doesn't have long enough lower tines . And that I mite have to lengthen them .
http://bit.ly/GIkCHa
Now I think I like these which look to be the same there made with the same metal and what not . Just ones about $300 cheaper over all .
There 74" only one has a weight 900 pounds seem heavy . So my worry is the weight .
The first two pics are from one dealer and its pics of there 66" Which has 6 tines there 74" does have 7 tines just like the other . And the other three is from another .
Look to be the same . Design and everything .
This rake style what I'm 100% sure I want .. Any thought on the weight on the m7040 . About a 200 pound difference.
The m7040 lift is 2300# or 2500# depending on which position its in .
Is a 900# grapple losing to much payload pick up.
Here's link to there 84"
http://bit.ly/1flFAaD
Here's link to there 74"
http://bit.ly/12u0SQ7
bandaidmd
B2620 w/LA364 FEL ,BH65, ssqa , 1982 B8200E w/BF300FEL
May 19, 2013
603
Middle of DELMARVA
My grapple is the same width as the tractor and i still end end with plenty of stuff sticking out both ends of the grapple. Your looking at grapples that are a foot wider than your tractor, imho that just runs up the price and weight and limits your maneuverability.
I like the extra bottom slats on my EA wicked grapple it all but eliminates any manual rake work.
Operator...Error
Kubota M7060 Ductape, Hammer, and Shovel
Oct 17, 2013
Springfield, Louisiana
When I was looking for a grapple I considered many factors. Construction of the grapple, weight/net payload. and what I was going to be using it for. So most things I pick up don't even come close to the limits of my Kubota. then the heavier stuff I just use it smarter. It all depends on what you are doing with it the 200 #s should not hurt you all that much unless you are moving huge heavy logs, large boulders, or chunks of concrete. I did have to modify my 72" Titan grapple where the locking pins of the QA go into the grapple to make a tighter fit. The ultimate reason I purchased the one I did was price. Everything can break so I don't feel as bad when I break something that cost me 1500 verses something that is at least 2 time that.
-Mike
78-79fordman
May 21, 2013
255
Gillham Ar.
How's that my tractors 6 feet and 6" or so wide . The bucket that came with the tractor is 72" and I'm looking at 72" and 74" grapples . The one I just posted the link to there wide one because the don't have there 74 " on eBay right now .
The price of the others that ain't Titan are . Just right at or around $2000 . And the Titan in around $1500 .
I don't like the EA wicked style it's more bucket design and double lid that don't crimp down far enough . I like the rake style like I posted . If I was to buy one from EA it would be this one . But it doesn't open but to 36" where the ones I above open to 48" . And it's way light only 460 pounds .
78-79fordman
May 21, 2013
255
Gillham Ar.
Found a dealer close that carries WildKat stuff and there the maker of the grapple that posted above . Was quoted $1700 for the 74" over the phone so I'm going to go check them out in person since the dealer says he has a ton of them that just came in .
78-79fordman
May 21, 2013
255
Gillham Ar.
Well I ended up with this wildkat its not the extreme like I was planning to get . As the extreme seemed way to heavy duty and it sure looks super heavy look'n in person . And the dealer didn't get the 66" in on the truck and the 74" just looked way to much of a monster .
We didn't have a weight of the one I got so I have to call wildkat and find out . It's got to be way lighter than the extreme . But still looks more than plenty stout . I got it in a 72" as the next size smaller was 60" I felt it wasn't that much lighter .
Got to dark when I got home with it and to cold to put it on and play with .
78-79fordman
May 21, 2013
255
Gillham Ar.
This wildkat grapple is 600 pounds and it is a $1500 grapple . That I bought .
It's seems plenty Stout thought .
78-79fordman
May 21, 2013
255
Gillham Ar.
Play'n with the grapple today .
Going to have to shim the quick hitch part up on the grapple has some slack . And get the hoses where they stay out the way . But over all going to be fun use'n it .
Skip44
Jeeps, L2900, FEL, tiller, brush hog,post hole drill, rock rake
Feb 19, 2014
116
Alexander, Maine
That looks like a real useful tool. I'll bet it would clean up my wood lot fast and give me some fun doing it.
Skip
CFDWheeler
57
Grant Co, Ky
I'm having a third function being installed on my loader as I type, while my tractor is back at the dealer for warranty work. I can't wait till I have enough money saved for a grapple.
78-79fordman
May 21, 2013
255
Gillham Ar.
Mine wasn't the money just the deciding which one . But I found the right one for me .
