stuck in 4wd
HC11
MX6000 Kubota, M5700 Kubota Equip. land plane,box blade,3 bottom plow,grapple
Jun 18, 2024
Maine
I have tried everything I know to do. I am not new to tractors. Went forward backwards, turned wheels, lift front end off ground. New kubota 6000----- I guess the next thing will be to lift rear end off ground
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,498
1,949
Western MT
Try changing the drive mode to N if that is an option. Don't forget to use the brakes if you switch to N. Otherwise, you might roll.
HC11
Jun 18, 2024
Maine
I went out and tried that no luck. I went through low,
med, high, neutral still wouldn't come out.
3,718
Some times, if you just put light pressure on the tram while you are trying to get out of 4WD it works,, only light pressure on the tram or it could be frozen linkage
airbiscuit
New Holland T2310, New Holland TC21D, Kubota l3010 GST, Farmall H
Mar 18, 2021
298
289
NW WI
It sounds like you are trying the usual fixes. On my New Holland shuttle, I'll put push the clutch in while I'm still going forward and pull up on the handle. Also, my lever is kind of stiff. I need to pull up on the handle sharply (give it a snap).
HC11
Jun 18, 2024
Maine
Mine is a hydro
airbiscuit
Mar 18, 2021
298
289
NW WI
You can still pull up on it sharply!
HC11
Jun 18, 2024
Maine
Mine to get out of 4wd you push down and I don't want to break something. The dealer is coming out to look at it first of next week. If he can't get it out they will take it to the shop. I do have a good dealer
airbiscuit
Mar 18, 2021
298
289
NW WI
Let us know their "trick"
HC11
Jun 18, 2024
Maine
I hope it is something simple to fix. It does look quite uncomplicated looking at the diagram. They came out and looked at it and it seems it will be going to the shop. For some reason that gear just doesn't want to disengage. Thanks for the diagram
5,521
curious, does the lever move 'freely' or some resistance ?
looking at NIW diagram, if it' free', then I suspect roll pin #060 is busted ?
HC11
Jun 18, 2024
Maine
There is resistance no play at all
5,521
rats, cause the drawing shows it's pretty simple, I was hoping for a SIMPLE fix....
it sounds like the gear is 'jammed'. I know my BX23s you have to 'go the other way' to release the 'wind up tension' but you've already done that....
sorry, my bag of straws is empty.
when it's fixed, please post WHAT they did, I'm sure everyone here would like to know.
airbiscuit
Mar 18, 2021
298
289
NW WI
Well, I was wrong. I thought they would find the right "touch" on site.
7,970
I owned an MX6000HST for a year and a little over 100 hours and have had the current MX6000HSTC for three years and close to 250 hours and have never had the issue described. It can be annoying when trying to engage or disengage 4WD, and there seems to be no rhyme or reason as to why it ranges from really easy to a bit of a struggle. As a point of comparison, it couldn't be easier with the M6060 which engages/disengages via a lever to the left that is either up or down, and there's a 4WD light on the dash too! 😂
I typically roll the tractor either forward or backwards a bit while gently applying pressure to the 4WD lever, applying more pressure as the tractor stops moving and that typically works for me. For the most part it takes a few seconds, but occasionally I have to push down on the brake, let up, roll forward/back. Looking at the owner's manual, there's a note that states ...
"If the front-wheel-drive-lever is difficult to set to "OFF", stop the tractor, turn the steering wheel, and move the front-wheel-drive lever. "
Interesting that the advice is to "turn the steering wheel" ... something I've never tried while messing with the 4WD lever.
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422
Jun 29, 2011
364
514
SE, NM
Just to be sure. Are you putting pressure on the lever while turning/backing up etc.?
