stuck in 4wd
BX23-S,57 A-C D-14,
5,780
curious, grabbed the MX6000 front axle shaft drawing and can see 2 possible reasons.
1)Looking at it ,my gut says maybe the balls have pooped out, 'somehow' ? I'm assuming this is the 'sliding' gear that transmits power to the front axle,if so,if the gear went past the 2 balls and spring, spring pushes balls out and 'locks' the gear into 4wd. Hard to believe gear could move that far though..
2) The other possibility is that the fork fingers 'magically' came out of the groove on the rear of the sliding gear #060. Say the rear lip broke off, gear could be pushed forward but NOT pulled back.
Now I've never had one apart, don't have xray eyes but it could explain the 'locked in 4wd'
If it was possible, inserting a borescope camera would be real nice. Get EYES inside BEFORE tearing the tractor down into 100s of pieces and costing $1,000s to fix.
I'm thinking #2 is the front runner
it will be interesting to hear what the dealer finds....
HC11
MX6000 Kubota, M5700 Kubota Equip. land plane,box blade,3 bottom plow,grapple
Jun 18, 2024
Maine
I just called the dealer and they came when I wasn't available and the mechanic was able to get it out, not sure what he did different than what I was doing but maybe putting allot more pressure on the handle. If it was going to break I wanted them to do it not me. I just went out and tried it and it came right out with no problem at all. I will keep putting it and out of 4wd now for sure. Thanks for all the reply's.
BX23-S,57 A-C D-14,
5,780
WHEW..... NICE.... sure better than tearing it apart !!
I'd be asking WHAT did the guy do !!!
Since these are straight cut gears, best to engage/disengage at a dead stop,neutral ( nothing spinning ) ? Maybe a slight rocking fwd/rev to relieve 'windup tension'
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,128
3,388
Nope. Room temperature RV antifreeze in a pump sprayer.
There was so much wet snow packed under the tractor everything turned to a block of ice overnight. The lever was literally blocked by ice.
BX23-S,57 A-C D-14,
5,780
yikes !! neighbour wondered why his snowblower smelled funny...HE never cleaned out he snow in the blower, it froze, starts it up,engages, then friction MELTED the belt.......
airbiscuit
New Holland T2310, New Holland TC21D, Kubota l3010 GST, Farmall H
Mar 18, 2021
317
317
NW WI
Glad it worked. Like I said earlier, the 4wd control on my New Holland is stiff to actuate. I learned that if I push/pull on it sharply, it actuates in or out of 4wd.
HC11
Jun 18, 2024
Maine
I have been taking it out after each use and it goes back in very easy ,not so easy coming out, but it does come out okay now. I am sure over time it will disengage easier.
