stuck in 4wd
HC11
MX6000 Kubota, M5700 Kubota Equip. land plane,box blade,3 bottom plow,grapple
Jun 18, 2024
10
Maine
I have tried everything I know to do. I am not new to tractors. Went forward backwards, turned wheels, lift front end off ground. New kubota 6000----- I guess the next thing will be to lift rear end off ground
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,404
1,826
Western MT
Try changing the drive mode to N if that is an option. Don't forget to use the brakes if you switch to N. Otherwise, you might roll.
HC11
Jun 18, 2024
10
Maine
I went out and tried that no luck. I went through low,
med, high, neutral still wouldn't come out.
3,495
Some times, if you just put light pressure on the tram while you are trying to get out of 4WD it works,, only light pressure on the tram or it could be frozen linkage
airbiscuit
Mar 18, 2021
226
162
NW WI
It sounds like you are trying the usual fixes. On my New Holland shuttle, I'll put push the clutch in while I'm still going forward and pull up on the handle. Also, my lever is kind of stiff. I need to pull up on the handle sharply (give it a snap).
HC11
Jun 18, 2024
10
Maine
Mine is a hydro
