I was young back then and didn't look at things the way I do now. Having to pay for your own toys makes a difference.
Damn, aint that the truth!
It's funny how that works.
I did read that and my first thought was I wouldn't be driving a tractor anymore if it were me. No way in hell I can afford that, no wayYou may have seen it already, don't recall where it was discussed. A friend of mine had to replace a front tire on his big NH 4WD. The belts seperated on it. Almost $900 for one tire. The rears cost over $2000 each. That's crazy.
Ok Slim, Be sure to take plenty of pics for us. I'm sure you will get most of this list done over the weekend.ptwyz,
Let's see
Pulling stumps of several different sizes.
Cleaning up the "wood lot" section of our property.
Installing a pond kit.
Digging a water feature, or pond in a wet area of our property.
Putting in an access on the other end of our property including drainage
culvert.
Rerouting a new driveway.
Leveling and regrading around our house. (Probably fixing a few drainage problems left by the jerk who did it the last time.)
Preparing a new place for our 28ft box trailer in the trees, and an escape route for whatever moves it into place.
Preparing spots for chicken coops and runs.
Moving some bushes and small trees around our property.
Moving some boats, metal and other clutter that has accumulated or was pre-exisiting to our purchase of the property.
Preparing a pad for a trailer or motorhome setup on the far end of our property.
Excavating a fountation wall and slab for a garage/shop.
Tilling and replanting with the proper vegetation to make our chickens, ducks, and local wildlife happy. Also as an attempt to remove as much of the underground root system for the local trash trees as humanly possible.
Digging a moat.OK, so maybe not.
And I'm sure that along the way there will be plenty of hauling of materials and friend and neighbor work to keep busy.![]()
Oh yeah, I also want to go out in the area and salvage a railroad switch which is down over a steep bank and bring it home as a decoration. Maybe there will be other neat things to salvage as well. Did I mention the wind turbine(s)?? Opps, and lets not forget the Groto to the Holy Mother.
That's a valid point. I'm not aware of any laws about carrying loads in the State of Vermont. I'm probably better off not looking it up.I'm glad to see your doing the smart thing and useing chains and load binders to tie that tractor down with and not ratchet straps. Just a word of advise and I dont know what its like up in your neck of the woods but down here in Virginia there are supposed to be 5 chains and binders on a backhoe like that. Four individual ones on the tractor alone and a 5th one going across the hoe boom to keep it from swinging side to side.
The DOT down here is geting rather anal about chaining equipment down.
Slim, I think I know the kind you mentioned. We used to use those in the Army when we loaded our stuff on flat bed rail cars. As a safety we would rap a strand of wire around the handle to make sure it couldn't come undone.I remember using some while I was in the Air Force that had a neat hook like handle lock. It went through the hole in the handle and when locked it could snap on the chain to lock it from popping open. Has anyone worked with those as well?
The kind you hade in the picture is way better. It was always a hit or miss to get the right link for correct tension. The ratchet is WAY better, no geussing and as the load does loosen later on just crank in a few more turns.I actually happen to have a few of those old lever binders that have a loop on the end of the handle. Big enough to put a pad lock threw. Usually what I dont so lever binder doesnt pop open is wrap the excess slack of the chain around the handle a few times so it wont pop open. The wraps from the chain will help to keep it from flying open. I use both the ratchet and lever binder. I cant begin to count the number of chains and binders I have but its ALOT!
