Fixing hole in side of block
jiggseob
B6200 HST with Allied loader, Muratori 48" hyd side shift tiller
Nov 12, 2023
51
41
Round Hill, Alberta, Canada
The big question at this point seems to be "is it necessary to remove crankshaft?" Theoretically, no.
Practically, I cannot visualize a scenario in which a connecting rod fails in a manner that punches out the block, and does not score/damage the crankpin (connecting rod big-end) journal. However, anything is possible.
However this proceeds, the crankshaft is not the place to skimp or cheap-out, reassembling at the loose-end of the service limit will probably only get you a few hundred hours, and next time it flies apart the whole thing may be scrap.
For the connecting rod to separate and punch a hole in the thick, very robust Kubota block, the rod had to be rotating metal-on-metal and knocking HARD for a while. The heat generated would have absolutely certainly contributed to the weakening and failure of the connecting rod. The other side of that friction surface, the crankshaft journal, will have been similarly heated. The crankshaft has more mass, so the equal amount of friction would have generated less heat in the greater-mass crankshaft, but that friction likely degraded the hardening of the surface of the crankshaft.
As a piece of the broken connecting rod stayed attached to the crankshaft and rotated around and punched out the block, the force of punching out the block would have been exerted on the crankshaft in a direction and manner for which the crankshaft is not engineered to withstand. It will be a miracle if that crankshaft is not bent beyond practical usability.
I hope the robust construction of Kubota engine has withstood this failure, and you can get it together and running reliably with the crankshaft in-place.
joesmith123
L295DT, BX1500
Mar 18, 2023
472
84
earth
I have been away from this project on a construction site but I am listening
I will do whatever yall instruct me to, and it will most likely be that I have to do the job properly, and get behind the block to take out the big crankshaft
I have gone this far, might as well go the whole way, right?
Yes I am imagining this statement, it is convincing me to have to go the whole way with this project
I should be back at this project maybe this weekend, but I am willing to go the extra route and do the job right
If you want to hear it before it blew up, there is videos on here from a year ago, and people did say there is a "knock"
Once I get it more apart, I will take pictures and yall can tell me what to do
I do have another L295 with 1500 hours that has a good block, I am sure yall can instruct me to:
Take out that engine, and use parts to make this engine proper/long lasting/not troubled
I need to learn/understand before asking/speaking, for example:
I am not sure whether I can take the crankshaft from the spare engine, and use it on this engine because:
I do not know the details of which parts are interchangeable, and which parts are specific to the block
I am sure one of yall knows the right plan, and we will get to it soon, take care
joesmith123
L295DT, BX1500
Mar 18, 2023
472
84
earth
Yes, I removed damaged piston
Not only is the connecting rod bent, but the piston is broken where the connecting rod hit it
On the piston with the damage, it looks like it slammed into the liner and did block damage
Do you see how the other pistons do not have this indentation?
With this issue, is it not that big of a deal because:
I can hammer out the current liner and replace it with another and it should be fine
Let me know if this statement is correct
No not true, the head can be swapped without changing the block.
You are going to need at minimum a new (used) connecting rod and cap, and 2 connecting rod bolts.
and rod bearings.
HUGE gamble that the mains are not damaged or that the rod journal (that threw the rod) will be in good enough shape to even accept a bearing, let alone run it without failure.
you can replace the connecting rod and piston, and leave the crankshaft in place, then you do not have to split the tractor.
I extracted these statements since they give the conclusion that at this point:
I can get from the spare L295:
Center piston assembly: piston head, rings, the connecting rod
Then get from messick brand new:
All new connecting rod bearings for ALL cylinders, all new connecting bolts for all cylinders
Theoretically, if I do these tasks, it should run fine, correct?
I understand that the recommended advice is to take out the crankshaft and also install new main bearings
As far as the location of the main bearings, yall are referring to:
Am I pointing at the location of the main bearings?
Messick does have main bearings 1 for $339, main bearings 2 for $209
If i also want to change the main bearings, where I have to remove block from tractor
Can I get main bearings from messick and they would work fine on this block/crankshaft?
Now, I am searching for acytelene oxy setup to repair the patch on the block
Forget Acetylene, use a mig welder with nickel wire.
I know the recommendation is mig welder and nickel wire
The problem: it sounds expensive and there is no electricity available, And
With the acetylene oxy setup, I can also cut steel for fabrication
At this point, it is the best bang for the buck
This is one I might go get on sunday, let me know if it will be suitable for these tasks:
1. weld the patch on the block with the hole in it
2. Cut 1/4 steel, and cut steel beams
3. Reintegrate the bucket that is broken in half
4. General all kind of welding: broken buckets, broken brackets, weld on a nut to be able to fasten onto that steel
I do see some say "cutting torch" as opposed to welding torch (I am guessing)
Can I cut steel and weld steel with the same torch?
Could I get this torch, and get nickel wire, and use that setup to patch the block?
I am gathering data, and not purchasing anything until I have a better plan
Feel free to critique and answer any of the issues/questions, no rush, thanks
5,908
I hate to tell you, that motor is done.
1: The chances of the block not having a water jacket crack and leak are very rare.
A hit like that send cracks up behind a dry liner.
2: And this is a Killer, you can not just beat out the liner and simply replace them.
You have to press the liners in and then you need to bore them to size.
These liners are not finish sized.
I order to do all of that you would need to strip the block down.
joesmith123
L295DT, BX1500
Mar 18, 2023
472
84
earth
Yes, if that engine is finished and not worth me tinkering with it, then, how about this idea:
The spare L295 (2500 hours, no hole in the block) will run, but will have leaks all over the engine etc
My plan: forget the engine with the hole in it for now, go and make the engine WITHOUT the hole in it suitable
I will go soon and drag that tractor with chains and park it next to this tractor
Then I will work on getting her started, my general question:
What should I do to that engine that will protect it and make it long lasting?
My understanding: If I change the connecting rod bearings, and the crankshaft bearings with NEW parts (genuine made in japan by kubota), then
Theoretically, that engine with 2500 hours should run silky smooth for a long time reliably
Let me know which direction yall would take if you were in my shoes, thank you
5,234
I would define the leaks you mention. Where are they, why is it leaking, etc. If engine has good compression and only 1500 hrs. I'd fix the leaks and use it.
Ktrim
B2400, lA352 loader,3pth quick hitch/z122r zero turn/restored 52 farmall super a
Dec 23, 2020
401
281
Nazareth Pa
You can plainly see damage to the rod journal in the pic.
joesmith123
L295DT, BX1500
Mar 18, 2023
472
84
earth
I would define the leaks you mention. Where are they, why is it leaking, etc. If engine has good compression and only 1500 hrs. I'd fix the leaks and us it.
I was only able to run it for 10 minutes previously before I decided to put effort into the engine that eventually blasted a hole in the block, BUT
I remember:
1. leaks all over the fuel system (those I can solve with new copper washers where the injectors sit)
2. Oil leaks from valve cover (fixable), Oil leaks from oil pan (also fixable)
Generally: the engine has 3 times as much hours as the one that blew up, some of the bolts have loosened, I will go through and fasten everything tight
I will today go and try to get it started for yall, and I want to get very close analytical details for y'all to critique and tell me what to do to make sure this engine doesn't blow up
I plan on getting very high quality video and maybe use a stethoscope for y'all to assess what I need to do on this engine so it doesn't blow up
the main question in my head:
If you got a 40 year old diesel engine with 1500 hours on it, what would you do to it to make it as reliable as possible?
What are the exact parts yall want me to change to make it last awhile?
My guess: change all the bearings because those are the "moving" parts, and that is where all the wear lies
Change: all the bearings on the connecting rods, and change the MAIN crankshaft bearings
So far from what y'all see, is this statement true:
If I would have changed the connecting rod bearings on the engine before it blew a hole in the block, there is a great chance that it would NOT have blown a hole in the side of the block
Since:
Once I took apart the area, we see that the connecting rod and the connecting rod bearings of the center cylinder were the main culprits
We are sure that: The problem was not the MAIN crankshaft bearings, but the smaller connecting rod bearings
I am asking, not stating these sentences
Please critique my statements, I am grateful
joesmith123
L295DT, BX1500
Mar 18, 2023
472
84
earth
Your statement: Where I have circled, one can see damage to the "rod journal", what I am circling is the rod journal
If I touch that part that I have circled, there is no noticeable indentations or alterations to the crankshaft
dragfan66
B7500 Z231KW G1800 L3350DT
Apr 12, 2020
Alabama
That journal looks very bad to me. I don't recall seeing the bearings from that rod in the pics.
Why not remove another rod cap and look at the bearing and the journal so you have something to compare it to?
The debris in the oil pan is a good indication that engine has to come out and be properly rebuilt.
joesmith123
L295DT, BX1500
Mar 18, 2023
472
84
earth
They disintegrated and were turned to shards, they are still in the oil pan, oil pan is filled with shards of metal, I am assuming that was the connecting rod bearings
I did remove rod bolts on front cylinder, looked at that rod bearing, that rod bearing was not damaged
And: where rod bearing connects with crankshaft, it looked the same as the rod journal of the damaged cylinder
yes plan with this engine: take off entire block and examine it to assess whether to go forward or not
make sure you can put in new sleeve for center cylinder, and make sure to lookout for what wolf said, check to see that it does not have cracks behind the liner of the center cylinder
meaning: do not put any more money into the block until I figure out that there is not more block damage behind the liner
dragfan66
Apr 12, 2020
Alabama
I remember:
1. leaks all over the fuel system (those I can solve with new copper washers where the injectors sit) Need to fix these leaks first.
Generally: the engine has 3 times as much hours as the one that blew up, some of the bolts have loosened, I will go through and fasten everything tight. You are hung up on the engine hours, what if it didn't have an hour meter? What if the hour meter is broken and you actually have way more hours than indicated?
If you got a 40 year old diesel engine with 1500 hours on it, what would you do to it to make it as reliable as possible? No one can answer that without x-ray vision.
Since:
See RED comments above.
Drain the oil and look for contamination or foreign matter.
Pressure test the cooling system.
Do a compression test.
Run the engine and look for unusual smoke, knocks, rattles, etc. and go from there.
But if you really want to be sure, do a complete teardown and overhaul.
Just my thoughts.
Ktrim
Dec 23, 2020
401
281
Nazareth Pa
As a builder of many engines, tractor and automotive, I have to say either install donor engine as it is or have it properly redone. Putting new parts in an old tired engine without at least polishing crank and honing cylinders; if everything mics up ok; is a waste of your time and money.
Bearings and rings will not wear into out of round or worn surfaces. They will self destruct.
jaxs
B1750HST
Jun 22, 2023
664
416
I seldom see someone on OTT i envy but Joesmith I would trade my front seat in the eternal inferno to be your kind of swashbuckler shouting "details be da__ed,full speed ahead" in the face of something like this.
5,908
Kubota Engines normally do way more than 1500 hour, I have 4 here that have anywhere from 2000 to 8000 hours and all of them run perfectly fine.
So with 1500 hours, I would put a gasket kit on it to fix the leaks and run it as is.
joesmith123
L295DT, BX1500
Mar 18, 2023
472
84
earth
Setup the second L295, dragged it using BX1500 and straps
L295 with 2500 hours, before I hit it with gasoline
All the parts in one pile from the L295 with hole in the block
Cleaning the 2nd engine, getting ready to fix it
Hit the damaged block with pressurized gasoline
So far I had to: extend a wire to give glow plugs power, installed the key switch from the other L295, Retightened all the top bolts
Next step: get this one running, then find all the leaks, and eliminate them, and look around for all the loose bolts and tighten those
I'll make sure all fluids are good, and get her running tomorrow
joesmith123
L295DT, BX1500
Mar 18, 2023
472
84
earth
Yes, I will be conducting these tests on the engines to solve issues and look for bigger problems
Engine with the hole in it: Next time I am fixing this engine, I can button it back up, and put pressure in the cooling system to see if the blow to the block caused it more damage than just the hole, and make sure she still holds water pressure
compression test: engine with 2500 hours and no hole in it: last time I had it running, I remember it sputtering off and I would have to hold the throttle to keep it running
I will do compression test on it to see the overall tightness of the cylinders
Meaning: if I put in new connecting rod bearings but leave the main bearings and NOT go through the comprehensive process of a overhaul, I am wasting time/money
(this is how I read this statement)
Honing/polishing: I did see the guy rebuilt this engine, youtube video in this thread, he polished and honed the cylinders/pistons himself, I plan on doing the same thing
Meaning: just because the area looks fine, doesn't mean that it is. In my case, that blow to the crankshaft might look like it did NOT damage the crankshaft, the damage could be hidden and could cause catastrophic engine damage again if I dont do the complete overhaul
(that is how I read that statement)
I made a mistake, the hours are about 2500, and the machine does look neglected/tough life
We will see what happens tomorrow once I tighten everything up, fix all the leaks
Once I get it running, I post closeup videos and sounds, and I do the tests yall tell me to do to check compression, valves, knocks, etc.
5,908
A compression test will give a better idea of the internal condition of the engine.
dragfan66
Apr 12, 2020
Alabama
You need to get some of those plastic totes with lids or something to keep all of your parts in.
If not, you will spend half your time looking for them.
