I bought a b2150dcd but the 3 point hitch and loader won’t work without revving up the engine. Anyone know what’s wrong?
How many hours on your machine?I bought a b2150dcd but the 3 point hitch and loader won’t work without revving up the engine. Anyone know what’s wrong?
Thanks for the help but there’s no screen there. That line on my b2150 doesn’t run there. It runs to the loader valve.See if this POST helps
Your tractor has a spin-on filter, right? No screen, I think. But there are rubber connectors with clamps between the sump and pump. Any leak there can cause a problem, that rubber elbow has been known to crack.Thanks for the help but there’s no screen there. That line on my b2150 doesn’t run there. It runs to the loader valve.
Yes, spin on filter. No screen. No leaks.Your tractor has a spin-on filter, right? No screen, I think. But there are rubber connectors with clamps between the sump and pump. Any leak there can cause a problem, that rubber elbow has been known to crack.
Those leaks can be tricky, there's no pressure so sometimes they leak under suction when they don't just sitting there.Yes, spin on filter. No screen. No leaks.
I am not into guessing.Yes, spin on filter. No screen. No leaks.
Thank u. Will check all these out. Where is the pressure release valve located!First off you have a B2150D not a B2150dcd.
Several options to what's going on:
Leak in the suction system.
Leaks in the suction side can present as wet spots and nothing more (look at all the green locations.
Weak / worn pump.
Wrong hydraulic fluid, that tractor should be using UDT or a good UDT substitute.
Bad / malfunctioning pressure relief valve, this is normally associated with all around weak hydraulics.
Plumbing done wrong to the loader valve.
Its been almost a week and still no answer to the most basic question.Thank u. Will check all these out. Where is the pressure release valve located!
Haven’t got a gauge to test that. Took the pump off and gonna put new seals in and see if that helpsIts been almost a week and still no answer to the most basic question.
Connect a pressure gauge to the pump discharge line and check pressure at 1000 and 2000 RPM. Do that with the hydraulic system cold. Then disconnect the gauge, run the tractor long enough to get the oil good and hot, and test again.
That will give you a good idea of the health of the pump. If there is a big difference in pressure between low and high RPM and it gets worse when the oil is hot the pump is likely worn and bypassing internally. With 2000+ hours that would not be unusual.
Buy one - they are only $20.Haven’t got a gauge to test that. Took the pump off and gonna put new seals in and see if that helps
I can't say this without sounding like a know-it-all, but . . .Haven’t got a gauge to test that. Took the pump off and gonna put new seals in and see if that helps
