Fixing hole in side of block
Status
Not open for further replies.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
hillbilly drift
the thread that took you back in time, brought back L295 diesel engine purring
present to you, the hillbilly drift
your robot jealous of supra
this is how it work:
you scrape at the high point going backward, then soon as you start going down,
cut your wheel one way all the way, swing your entire robot 180,
the blade slicing at your high point, then keep churning earth, no stopping of your momentum
woah, elite level hillbilly disclosure, witness you it
you can see in the clip: she'll lug down but you already turned your wheel straight and she'll power through
wow, lik japan ninja, she slice your high point without even making you switch a gear
and do 180 like nothing happen, keep churning your realm, your lost in your boxcar song
behold your japan robot ninja, twirling on the high point, planing out your realm
61 page into your thread, japan ninja twirling and doing hillbilly drifting
bust your exhaust right off the manifold, unbelieveable
park your robot back in your shop, behold you the new realm reveal by your twirling ninja
WI_Hedgehog
Apr 24, 2024
867
1,197
Milwaukee, Wisconsin, U.S.A.
The math doesn't add up.
With as many hours spent "leveling ground" as claimed the confined space should have started out as the side of a hill, but it started out relatively flat.
It was a couple hour job with a hand rake, there shouldn't be this many breakdown...unless...
3,219
I would have graded the area to shed water, not retain it, but that's just me.
Looks like the only dry areas are the edges.....
9,380
Joe.... Why don't you start reeling it in.
I think we've had enough of the acid trip rambings.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Broke the big support
busted big support, no acetylene available
fill up acetylene, weld massive 90 bracket
What your doing:
lug earth from the high point bringing it into the low point
doing 180s lugging earth from high to low, breaking down the high points,
using the mud as an indicator to tell if it need to go lower
if mud travel there, you know it is low enough to let the puddle escape
yes, no more acid trip rambling, only use the thread to share/document the fact, no more personality
wheel broke in half from the stress of the 180 degree turn
busted exhaust held by copper ground wire
wheel about to snap off
machine down, need to fix:
major weld on broken fel support, weld on busted exhaust manifold, get a new wheel, seal up the other bucket cylinder, replace busted hydraulic hose
also look for big steel bracket, straight and 90 for when you need reintegrate broken support
Moose7060
Oct 14, 2023
827
2,243
bc
It’s ALIVE!
Mostly😎
OP…this thread will go down in the history of this site. Not exactly sure what for…but HISTORY damnit!
My guess this thread ends on April 1st. 😂
Chanceywd
Mar 26, 2021
731
675
central ny
Maybe long past the time to do a little reading or videos on your welding process. I taught my self from a high school book a shop class teacher gave me in the 70's.
You need to understand surface prep, tip sizes, gas pressure settings, neutral flame, working the puddle, movement of the torch and using a readily available filler rod, not just a bolt you pick up. How you work all that is way different than just heating it until it is molten and dripping.
Most of your welding process could be greatly improved with one set of tank fillings.
It is like baking a cake, you don't substitute salt for sugar just because they look the same. Adding more liquid won't make a bigger cake. You follow the recipe and your method is the recipe for failure and doesn't need to be.
L35
Jun 13, 2010
629
656
CT
Your rim looks like it’s had loose/missing lug nuts for a period of time, that may be what caused the cracks vs turning and churning.
3,219
What oxy/acetylene welds should look like.
Reactions: 6 users
Hugo Habicht
G1900
Jun 24, 2024
908
1,279
Ireland
April 1st, 1899 if I remember right.
That explains it :)
Originally this thread was ok but now Joe messing up the tractor with his "welding" beyond a chance to repair it properly it is only sad I think.
Truly beautiful welds, absolutely perfect ! (y)
I will never be able to achieve anything like it, I have to revert to grinder and paint :giggle:
3,219
Over the years, I have made lots of OA welds that look like that, usually at the end of a long project.
However, I use OA so infrequently, that but the next time I need to do it again, I have lost my touch and weld like a beginner again. ;)
Throughout my career, I never had to weld much, because we always had NASA certified welders on staff.
No sense in me doing it when we had that kind of talent around.
3,264
Amen to that. Believe it is the same for any type of welding. Not like riding a bicycle...seems to take more time to get back to wherever you were when you welded last...but still, you don't lose everything.
If one has some experience with OA welding, doubt in a single lifetime he could regress to where Joe is. Not to fault Joe, he is trying to do it without any guidance, at least guidance that he is willing to listen to.
Get a stick welder is advice that is give here now and then, but even with stick it takes time. Wirefeed may be most forgiving, but with that too, you can easily make joints that look good, but fail immediately.
My take on it anyway...
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
make progress on your repair
fill your welding tank
lift tractor to change the broken rim
got another wheel with tube and used tire
some of those lug studs fell and got lost, find similar bolt and put them in tight maybe with glue
broken massive support, plan: grind it all down, put you big clamp, then brainstorm your plan to weld something in there that would work
probably cut thick steel 90 laying around, maybe 2 of them, youll figure it out, no decision yet
get you couple 24 inch hydraulic hose from surplus, very good price
summary: put you on your non broken rim and find spare studs, replace the busted hydraulic line on bucket cylinder, decide the exact setup for the big weld on the broken fel main support, and make some progress on your bucket cylinder hydraulic leak
Clean the wheel studs with solvent, cover them in glue, put them in tight then put more glue on top of stud
Go through your other L295 parts and take bolts from it since you lost 3 studs when rim broke
Back of your rim cutting into your front axle
clean bolt with solvent, cover them in glue, hit them hard with air impact
took out the busted hydraulic line, put in new hydraulic line
at this point, you look at machine, and you notice more problems that will lead to bigger problem, list you all the problems that are concerning:
support that go down and connect two rails to tractor, busted out couple bolts and is loose, causing more stress on your entire loader connection to tractor
metal clamps that go over your hydraulic line that keep the lines connected to the big rail, busted off, you couldn't find bolts that fit
FEL loader valve busted off again when you last ran out of welding gas
leaky injectors at the head thread, oozing out diesel, causing it a bit harder to start since it need to prime diesel line, hydraulic leak at bottom of hydraulic pump,
when you couldn't find a bolt to secure down your hydraulic lines to the loader, you went on this multi hour cleaning binge, tossing tons of garbage, making piles of related tools/whatevers
you put nails all over the place and start hanging ton of tools closer to your machines
threw away tons of redundancies
while you were cleaning, you reflect and conclude:
no using machine until it is absolutely secure structurally, meaning
all of your heavy metal structures completely supported
your busted fel valve is solved, your plan with this problem:
because you cannot get a good angle for your flame in that tight spot, you will experiment with:
drill holes and put bolts that will fasten the broken connection that keep breaking
general problem: the machine is powerful and will keep busting off bolts even if they are fully fasten
you will be going through all bolts that keep loosening and glueing them tight, experimenting with solving this issue
like @Lil Foot suggest: put a beam across the two rails that connect them in hope of adding more structure to the loader
the big weld: you still have not come up with good idea to reintegrate the massive structure weld that broke
one idea: put a massive thick steel plate that encompass the tear, the plate would bind to one side, then you heat it up and hammer it to take on the shape of the bend, then bind it to the 2nd entity
Since the tractor welds seem to be breaking at the weld line maybe try using a ball peen hammer when still hot. It would compress the material for strength. Used to be known as blacksmithing.
this is the statement that lead you down this path
you'll be experimenting with, fusing one side very well, then heat up your metal, shape it with hammer while still hot, get it to take the shape that you want, then fuse it to the 2nd entity
summary: you started to make progress on your repair, realized there are too many problem, couldn't decide what to do, then went massive cleaning binge to clear your mind/work area
while cleaning, you consolidate the order of task, and decide:
the structural integrity of FEL connection to the tractor is priority #1, worry about everything else later
plan: do you ton of custom metal work to structurally hold together all the steel: the big two rail connection, the massive broken structural weld, the FEL valve that keep busting, and
that front plate that hold two rails that connect to front of tractor: it is very hard to get the bolts in and you mighta stripped the threads previously trying to get them in at slight angle
might experiment: tighten you the remaining bolts hard, then melt you bronze on top of bolt into the plate it hold,
that way, it cannot rattle itself loose
summary: you are so tired of your machine coming apart/breaking, that you are going on a massive and deliberate operation of holding it all together using big bolts, tons of drilling, welding, and other brainstorming tactics
no using machine until everything fully and completely secure
this challenge is proving that the thread is correct, that if you cannot solve this problem, you cannot use the machine
9,380
Ok we've gone into a whole new level of insanity, wood glue on wheel studs! :rolleyes: 🤪 🤯
Reactions: 6 users
Chanceywd
Mar 26, 2021
731
675
central ny
I believe this might fit the definition of insanity,
"Doing the same thing over and over and expecting different results"?
Status
