B7100 hard to start
Brandonallen
1991 B7100 hst 4x4
Dec 4, 2021
20
Bottle feed the injection pump again, that will eliminate any fuel delivery issue and give you a better idea where to look.
You said you cracked the overflow line fittings to get it to run the last time, well that step seams rather odd, that normally will not help them start or run any better.
2 things to check.
The fuel level, has it gone down while sitting?
Check the motor oil level, has it gone up while sitting?
Oil level seems to be where we left it. Fuel does as well. I’m not sure if cracking those return lines helped air get pushed out or what. Maybe the injectors got clogged up sitting for a month while the block was getting sleeved? Almost has to be fuel related since it was running great two days ago
6,651
Pull the injector lines, set the throttle to high and look at the injector fountains coming out of the injection pump, are they all the same height?
Should be about 2" give or take.
6,651
Yep Injectors.
I would either get a local injection shop to test and rebuild them or get a set from Oregon fuel injection.
There is a lot of injectors out there on eBay, and Amazon and other sellers that are complete junk.
Brandonallen
1991 B7100 hst 4x4
Dec 4, 2021
20
Yep Injectors.
My local shop wants 25 a piece to test and 100-115 to rebuild. Is it worth removing injectors and hooking lines up facing outwards and cranking it to watch spray? Seems like we are at the end of the troubleshooting with everything else checking out
6,651
Yes you can do that, use a piece of cardboard to see the pattern, NOT a BODY part! ;)
Brandonallen
1991 B7100 hst 4x4
Dec 4, 2021
20
One is misting, one is squirting without mist and one is like halfway squirting. Going to get replacements. The Oregon website says 3-7 days. Is there any other reputable sites to get oem or quality injectors?
