Fixing hole in side of block
ken erickson
Nov 21, 2010
1,094
1,802
Waupaca Wisconsin
People saying dont run it without coolant:
Yall realize there is 1.5 gallons of oil it?
I bet i can't overheat it if I tried
I would not bet the farm on that one. The 1.5 gallons of oil do not run in coolant passages surrounding the cylinder liners and head wicking away combustion heat. JMHO. In any case I would not run the engine for more than a minute without coolant, I am too lazy and too cheap to replace a cracked head! LOL
Chanceywd
Kubota L2501DT BH77 VIRNIG URG60-CT 1950 8N
Mar 26, 2021
584
423
central ny
Back in the 70's I rebuilt a 196.6 6 cylinder engine in a 64 rambler. I did rings, honed it, rod and main bearings, valve job the whole thing. It wouldn't start when I first tried and wound up cranking the battery down. I took a break while it charged and foolishly had a couple beers with my lunch. But I figured out that the distributor was probably 180 deg off. Checked when I got back to it and it was. I then tried and it started right up, running really smooth. I let it idle for probably 10 minutes and it started to get rough so I reached over and blipped the throttle once and it caught on the hose clamp for the coolant manifold preheat tube. I thought I better move that clamp before it becomes a problem.
It was then I realized I had oil in it but no coolant. It had broken the rings in the 3rd and 4th cylinders from lack of coolant and me having my coolant didn't help.
Not a happy moment when I was on a limited budget and had to start over.
Bill
2,802
Bill
I think the error in your ways was not putting enough personal coolant into your system!
Had you done that properly you might’ve put off doing anything until the next day and realized where you were at with the vehicle engine, and checked for proper lubrication and coolant before you tried to start it!
:ROFLMAO:
Vlach7
L47 305DT JD500C
Dec 16, 2021
316
223
Frazier Park Ca
When I rebuild stuff I might run it for 5 seconds. Why take that chance? I wasn't impressed with the oiling of the parts in the first place. Like you were waiting for it to seize.
