5,123
Moose7060
Oct 14, 2023
496
1,102
bc
1,396
How big is the tank? The herbicide I get from the AG store is mixed with 15 to 25 gallons of water per acre. Most farmers use it around here. $300.00 a 4 litre jug.
That drone is probably using a spot spray technique that minimizes the amount of herbicide used. There are machines that can visually scan an area and identify the location of the individual weeds and then spray just those weeds. They are using really incredible technology.
Moose7060
Oct 14, 2023
496
1,102
bc
That makes sense. Thanks for the info! Pretty impressive machine. I guess the 4 acres in 10 mins would really depend on the amount of weeds to spray then.
Moose7060
Oct 14, 2023
496
1,102
bc
Siesta Sundance
Oct 23, 2022
1,534
1,899
youtube.com
And I bet those herbicide chemicals your using were developed 40 to 60 years ago! Just like using newer technology in using drones, newer chemicals(2020 epa appoved) have also been developed. It's important for us(farm, ranch, land owners) to attend AG events like the one I attended yesterday.
Envu and Corteva(DuraCor) have herbicides that only take a couple ounces per tank of water.
I don't have an applicators license to buy those chemicals.
I buy Triclopyr 4(non cancerous herbicide lol) herbicide in a case, 2 x 2.5gallon jugs, runs about $260 for the 5 gallons. I mix a quart per 15 gallons, a very strong mix for fence lines. Keep in mind, the plants, cactuses, brush, trees are complete bad asses to live in an environment down here. Triclopyr 4 is stronger and cheaper than Remedy.
Here is my goto guide for applications.
Siesta Sundance
Oct 23, 2022
1,534
1,899
youtube.com
The entire 4 acres was sprayed.
The drone can be programed to target specific areas, especially areas where tractors can't go.
The same company that sells the drones also has company that does applications.
So there is a lot of factors, targeted plants/trees or general field spraying, spray rate ratios etc.
The guy said $20 acre or $350 hour
On average it can cover 25 to 28 acres an hour with return refills on the tank, based on spraying herbicide/water 2.5 gallons per acre on a grass pasture. Chemicals provided by customer.
Moose7060
Oct 14, 2023
496
1,102
bc
I've been using this Pyralid.
Pyralid Herbicide is for the control of perennial and annual broadleaved weeds in field crops, Christmas tree plantations, pasture, rangeland, vegetable and fruit crops, and non-cropland. Registered Crops: Wheat (spring) Barley and Oats, Oilseeds, Grasses, Non-crop, Rangeland, Strawberries, Cabbage, Cauliflower, Broccoli, and Others (see label). Weeds and Rates: 0.504 L/ha-Canada Thistle (top Growth), Vetch, Alsike Clover 0.672 L/ha-Canada Thistle, Scentless Chamomile, Wild Buckwheat, Perennial Sow Thistle, Common Groundsel, Volunteer Alfalfa, Common Ragweed. 0.996 L/ha-Canada Thistle (season long control with reduction in population the following year) Packaging: Case: 4 x 4.45 L 1 case treats 88 acres at 0.504l/ha 22 acres per jug 1 case treats 66 acres at 0.672l/ha 16.5 acres per jug 1 case treats 44.7 acres at 0.996l/ha 11.2 acres per jug Tank Mixes: Glyphosate, Clethodim, Odyssey, MCPA Amine or Ester, 2,4-D Amine or Ester, Tralkoxydim, Assure II, Yuma Assert, Axial, Clodinafop, Everest, Fenoxaprop, Flurasulam, Refine Extra, Poast Ultra, Pursuit, Fluroxypyr, Solo, Muster. Water Volume: Ground: 10 GPA or 45 litres / acre for optimum control. Do not Aerial apply. Storage: Store in heated storage; If frozen warm product and agitate. Rainfast: May be up to 8 hours depending on tank mix partner Grazing: May be grazed immediately
Siesta Sundance
Oct 23, 2022
1,534
1,899
youtube.com
Good deal. So it's relatively a newer herbicide, ~2005. But it appears to have some of cancer causing chemicals in the ingredients.
Siesta Sundance
Oct 23, 2022
1,534
1,899
youtube.com
One of the classes yesterday was on how to calibrate the spray tank boom and boomless sprayers. This ensures your not wasting or putting out too little of chemical. Very informative, cause it can save you money, as you know these chemicals aren't cheap. The calibration should be done yearly and after cleaning the screens/replacing tips/or changing tips out for different spray degree nozzles.
Moose7060
Oct 14, 2023
496
1,102
bc
That's good advice. Thank you.
Seems like most things now days comes with a may cause cancer warning. Simple precautions and common sense limits risks. Using a mask, long sleeve cloths and shower afterwards are helpful. A cabbed tractor is good as well.
Siesta Sundance
Oct 23, 2022
1,534
1,899
youtube.com
The farm house we just bought over the summer, the priors owners got a divorce. He had signed over the house and land to his ex.
He lost his house & land.
He lost his wife.
Most importantly, he lost his Johnson too! lol
Siesta Sundance
Oct 23, 2022
1,534
1,899
youtube.com
lol always make sure you know your surroundings!!
I went to go check on cows, and I was about to pet my bull, except it wasnt my bull. They were in the shade and I didn't even notice the visting bull didn't have a white mark on his face. Well that was a oh shit moment, lol. The visiting bull didn't seem to aggressive, so that's a plus.
Not mine.
Mine.
5,123
He lost his wife.
I'm reluctant to say my Johnson is much larger and of better apparent construction.
I wonder if that caused some of the domestic unrest...maybe she tossed it aside for a larger and better built Johnson?!?!? ;)
Siesta Sundance
Oct 23, 2022
1,534
1,899
youtube.com
Researchers at Kansas State University found the 2022-2023 drought over the central U.S. drove a 37% reduction in wheat production compared to average production. In addition to yield loss, crop abandonment (a measure of the difference between the area of wheat planted and area harvested) played a large role in this production loss. In 2022-2023, the U.S. wheat belt recorded the highest level of abandonment since the middle of the Dust Bowl period.
