Good day.I spent about 2.5 hours trying to connect the PTO shaft from my MMM to my BX2380. Every spring it's the same thing. The collar on the connector won't stay in the unlocked position. I've cleaned and lubed it, but nothing works. If I get it to 'stay' clicked back, the slightest touch will put it in the locked position. Plus the weight of the shaft makes it impossible for me to at least get it started on the tractor PTO and then pull the collar back.. (I'm not the biggest, strongest guy.) Any suggestions would be appreciated. (Or I don't mow during this coming grass growing season!)
I am not sure what is right, and I sure each have their own method that works best…for me I do several things:
1. A little bit of grease.
2. I put a wood block under the telescoping shaft to support it (that allows me to change position or adjust my hands without setting it down…having the shaft suspended IMO makes a huge difference.)
3. I come at it 2 ways…first time I am close to perpendicular to align the spline by rotating and pre set the collar once it is on the tip of the shaft…second time I come at an angle and just reach up to the suspended shaft / collar and finish the job (I change positions to this and use both hands so I can hold collar back and slide forward…long arms help as I can’t get my shoulders under there
I am not sure that helps or makes sense, but that seems to work for me.
