Bri-Guy-GA
Kubota BX1880
Sep 10, 2020
178
117
Villa Rica, GA
The BX line of tractors don’t get much credit here. Great machines for the jobs needed on small acreage. Now if I had 25 acres, I would be owning a lot larger Kubota. It may take a little longer to get the job done but the job does get done. Enjoying mine.
I can second that. The BX's seem to be lacking respect, but it do what you want it to do just a bit slower.
Outnumbered
Kubota L3901, FEL, BB1260, RCF2060, FDR2572, Titan Forks, Caryall, 5' Tiller
Oct 26, 2019
233
423
Moseley, VA
Hah, I know it's not orange. I let the Kubota rest in the shed today after moving a bunch of dirt and rocks yesterday filling in around some 12 inch drainage pipe so I can cross a wet weather drainage area. Today I woke up the ole Ford, changed the fuel filter, changed the oil and filter and then dove into the oil bath air filter as I had never touched it since taking possession of it a few years ago. Well I wish I had taken pics of the before and after as it was about 90% blocked and I am assuming it had not been cleaned in 20 years or more. To be honest, I don't know how the old girl still ran with that restricted mess. Long story short cleaned and back in service today.
Reactions: 11 users
5,124
I have a 4WD Ford model 1920, with FEL
Love that little 32 HP (Shibaura) bugger.
mdhughes
L3901DT
Dec 10, 2014
1,298
914
Ste Geneveive county, MO
Sunday I moved four bucket loads of ash. That's a year worth of ash from the wood burning boiler we use to heat our house. It had rained a couple of days before, so it was a little easier to move than when it is dry. The only bad thing was I had to get off the tractor and use a shovel to get it all up and in the bucket.
4,536
If you spray your bucket with diesel fuel before moving sticky stuff it can be pretty helpful in getting the load to let go.
I’m not sure if that’s still politically / environmentally correct. Sometimes I have a hard time keeping up with all the changes in “acceptable”. But it does work.
Edit: Reading that back, maybe I misread that the first time and the shovel work was getting the last of the ash in the bucket, not having to shovel sticky wet ash out of the bucket. If so, my bad…
4,411
Snuck out after lunch today to do part 2 of a small grading/seeding job. Was done in 2 hours with a couple of yards of screened topsoil. Made some nice coin for a small job...just the way I like them.
didnt bother with pics...looked like last pic in post 18,451...a little bigger area with seed and straw ;)
5,124
"acceptable" is an interesting issue.
How is it "acceptable" when road resurfacing, to initially apply thousands/millions of gallons of hot thick oil "tack coat",...... often referred to as "road oil"?
7,952
My neighbors had $4k of gravel delivered over the past couple of days and had quite the mess outside their house with large piles of 3/4 crush. They asked me if I'd get the piles moved and leveled since they don't have any way to do that sort of work other than with shovels and a wheelbarrow.
I used the new bed mounted fuel system to fill up the MX this afternoon. So much easier than 5 gallon containers.
Reactions: 14 users
7,952
Later this afternoon I moved the land leveler to the M6060 and tried to improve the lower common driveway. My neighbors had a bunch of gravel dropped there too and it's soft and deep in places. It'll be a while before I can get it sorted out since we don't have a roller. Once we've had some traffic on it I should be able to do a better job of getting it level.
The M6060 is such a beast of a tractor and it'll pull a fully loaded land leveler up hill in mid range and 1st gear.
Reactions: 14 users
S-G-R
LX3310
Jun 17, 2020
1,176
2,460
PEI Canada
You've got beautiful scenery out there.
7,952
For sure ... and thanks! As I was driving up the edge of my property to my neighbors, I could see 40 or so elk on the hillside. They're about 1,000 yards from my house in this photo which was taken near the top of my place. If you look in the center of the bottom photo you can see the elk.
Reactions: 7 users
7,952
Don’t think I would try one. I have a kind of deep ditch to mow Besides my yard. Thought about it before getting my 1880 but needed something for snow removal and a loader For moving dirt around. Was my 1st time removing and putting it back on so hope future movement gets easier.
I'm in your camp. I've never owned a zero turn and likely never will. I cut with a rotary cutter, flail and this year also with a folding cutter. Small wheels and tires don't work well for me with the kind of cutting I do or the terrain I have to deal with. I don't have to worry about cutting around trees or under stuff. I typically cut large areas such as these fields. If I see a zero turn out here it's getting mulched! 😂
flyidaho
L 3301 HST
Feb 28, 2017
428
253
IDAHO
I unloaded the 6' brush hog from on top the trailer where it's stored all winter, inside. The cherry picker inserts into the receiver of my fork lift rack, held in by compression, 2 chains sit in notchs cut into the top part of the frame, it comes off and on in about 30 seconds. Made out of "stuff I had laying around" and just until I made a real picker, but it's proved to be good enough.
Note to self: remember to de-rig the cabling used to lift it, securing it to the mower deck, away from the drive line, BEFORE first use!
5,124
I unloaded the 6' brush hog from on top the trailer where it's stored all winter, inside. The cherry picker inserts into the receiver of my fork lift rack, held in by compression, 2 chains sit in notchs cut into the top part of the frame, it comes off and on in about 30 seconds. Made out of "stuff I had laying around" and just until I made a real picker, but it's proved to be good enough. View attachment 126537 View attachment 126538
I like my BH for simple tasks like this.
A short piece of chain, and away we go!
flyidaho
L 3301 HST
Feb 28, 2017
428
253
IDAHO
I did the mower moving after a 10 hour day operating my 30 ton boom truck, hydraulic systems are one of the best inventions ever, for sure, under appreciated by most, not us!
5,124
Curiosity: What are you using your boom truck for?
7,952
Nice! I have a CAI SSQA boom pole but haven't used it yet. I bought it to raise steel trusses up in the air and will be using it this spring for sure. Using a backhoe to unload equipment is limited since you can't easily or safely pick up and move. Now an excavator is a whole different animal and way more capable than a backhoe when it comes to this sort of thing. I've unloaded a lot of equipment from trailers using the FEL. I never picked anything off a trailer using the backhoe when I had the BX25D.
I used a to run a boom truck many years ago when I worked as a diver/welder. The same limitations apply to the boom truck, but it was good to lift a big diesel hydraulic pump on and off the bed at a job site. We used to cut concrete piles using a Swiss-made hydraulic ram and needed a large pump to run the equipment.
5,124
Thermos bottle is best invention ever!
You put hot stuff in there,..... it keep it hot....
You put cold stuff in there......it keep it cold.....
How do it know? :(
ely4donnie
I spent about 2.5 hours trying to connect the PTO shaft from my MMM to my BX2380. Every spring it's the same thing. The collar on the connector won't stay in the unlocked position. I've cleaned and lubed it, but nothing works. If I get it to 'stay' clicked back, the slightest touch will put it in the locked position. Plus the weight of the shaft makes it impossible for me to at least get it started on the tractor PTO and then pull the collar back.. (I'm not the biggest, strongest guy.) Any suggestions would be appreciated. (Or I don't mow during this coming grass growing season!)
