I have an LX2610 with approx. 170 hours. The tractor is no longer under warranty. After moving some logs, which the loader handled no problem, I noticed the loader seems bent. I made sure all the support bolts are torqued to specifications, a couple were only slightly loose. No welds appear to be broken but from inside the cab you can clearly see the left side is slower to lift and faster to return to ground. Attached are a few pictures on level ground. The closer to the cab the more level the loader arms. What else should I check? How best to determine the exact problem and how to repair? Thank you.
