Stomper
2017 L2501. Landpride Mower. Farm King Snow Blower. DIY Root Bucket grapple.
5C............At what temperature in cold weather should a tractor be plugged in for safe easy starting.
I plug mine in when it get below 40°F. It starts easier and warms up faster saving wear and tear on the engine and the battery. Two hours is enough.At what temperature in cold weather should a tractor be plugged in for safe easy starting.
On the advice of fellow forum members I got a remote receptacle set up. In winter I plug it in all the time and when I get up I hit the remote control and then have my coffee without having to gear up. Less than $50.I keep mine in the garage so I'll plug in if it's under 10-F, go back in, have a cup of coffee then move snow.
What the Wolfman said. My 50+ year old John Deere 2020 diesel needs to be plugged in if the thermometer falls below 50 degrees. My 2016 Kubota M7060HDC12 fires up just fine at 20 degrees. If the tractor is gasoline powered starting should be no problem as long as the battery has the power to turn it over.It depends on the vintage of the tractor, Older needs to be earlier.
I don't bother plugging in until it in the 20's F , otherwise they start fine every day.![]()
I'll second Torch's comments. If I have the luxury of time I'll plug the tractors in before starting at temps below freezing. Below -10C no attempt to start is made without preheating. I've discovered that a kerosene or propane salamander-style heater aimed from the front of the tractor rearwards helps warming the engine and transmission, if that's all that's available.
Once running the machine gets to run for a bit to warm up. The hydraulic fluid really does take a bit of time to take on some heat and flow nicely.
Can you give more details on what block heater you use so I can google it. Never had a diesel before so I am clueless.It always amazes me how much quicker and easier my BX starts on a cold day, no turning for 10 seconds and big black puff of smoke. I have it stored in an un-heated shed and have the block heater connected to a wifi controlled AC switch. These things are crazy cheap on ebay ($10). You just turn on/off the block heater using your smart phone anytime you like. You can even program on/off times for that early morning cleanup.
Cheers
First dealer said I wouldn't need it, and I think the second mentioned leaks. Seemed odd that they'd miss a chance to make more money, but maybe they are an agravation to install. I have not had occasion to start mine below about 10 F, and no problems. I think you are likely colder. We get subzero weather, but I avoid lengthy times out side. I do put trickle chargers on the batteries." I have 2 fairly new tractors and two different dealers recommended against installing block heaters "
I would be interested in their thinking on not installing heaters. I did not even ask for mine, the dealer installed it as a normal setup and I am sure our winters are similar to your's. Just curious. I did not plug mine in one day when it was cold and when I started it I could really tell the difference, did not like the way it sounded at all.
