L3350 front drive shaft
David18902
L3350 l185
Jan 4, 2017
Nipomo, ca, usa
Hi. Looking for the front driveshaft (between transfer case and front axle) part # 32560-44290. It seems to not be available from kubota and shows up as discontinued through U.S., Canada, and Japan Kubota. Any ideas?
rbargeron
Jul 6, 2015
1,169
235
western ma
Has your shaft failed at the couplings? Post a picture? The tricky part is the splined end joints. A machine shop could make a new keyed shaft and modified couplings?
1970cs
1,124
Grand Ledge
DVoss
L4150
Jun 24, 2016
37
Zimmerman, MN
It's not that hard to make one, if you have a sample to go by. The spline itself is the hard part. it's going to cost some money to have the splined hobbed on one piece. Then there's the connection slip joints....if they are like the L4150DT.
I'd be happy to make it....if you have a sample. But, it's going to cost some real money. Material, machining, heat treat.
DVoss
L4150
Jun 24, 2016
37
Zimmerman, MN
Just looked at the schematic at MBTractor...the shaft is very similar to the L4150. The couplers are available...maybe. I'd be inclined to make the shaft.....it would keep everything OEM.
6,062
That's because it is the same shaft. :p ;)
David18902,
When looking for used parts all of these model tractors take the same shaft:
L3350, L3750, L4150, L4350.
