Hi. Looking for the front driveshaft (between transfer case and front axle) part # 32560-44290. It seems to not be available from kubota and shows up as discontinued through U.S., Canada, and Japan Kubota. Any ideas?
Has your shaft failed at the couplings? Post a picture? The tricky part is the splined end joints. A machine shop could make a new keyed shaft and modified couplings?Hi. Looking for the front driveshaft (between transfer case and front axle) part # 32560-44290. It seems to not be available from kubota and shows up as discontinued through U.S., Canada, and Japan Kubota. Any ideas?
No sir it's no longer available! I checked all dealers in North America and all obsolete parts warehouses don't have it either!When I look it up it shows it as still avalible?
Might be a long shot but try these:
http://www.colemanequip.com/parts/KubotaParts/32560-44290/
http://www.goldeneagledirect.com/index.php?l=product_detail&p=100427
http://www.tractorx.com/kubota-32560-44290-propeller-shaft-genuine-oem
That's because it is the same shaft.Just looked at the schematic at MBTractor...the shaft is very similar to the L4150.
