Zg127s replacement engine
Temler
Zg127s
Apr 14, 2022
Hi all.
I need to replace the engine for my zg127s, it has 27 hp kohler now. Sv840- 3043. Where is best place to put new engine. Is there a better engine I should put on. Please give me some ideas
Thanks
Temler
5,527
What went wrong with the original engine ?? If you replace with the SAME make/model, zero rewiring, zero mechanical issues.....
JasonW
384
191
Al
X2 what happed to the original engine?
I have the same mower with about 250 hours and it seems I work on it a lot more than I should. Last year I had the engine tore down chasing a hard start issue and currently had to re weld the muffler where it cracked and blow a hole in it. Seriously considering upgrading.
Edit. When I had my engine off I considered a replacement. There is only a few wires for the electrical, just match an engine with the same crankshaft specs for the PTO clutch.
5,386
2,081
I have the same mower. It was given to me, had IIRC 21 hours on it (70 now). When I got it, the engine was trashed. I got it started but it wasn't any count. She ran it out of oil. VERY common with Kohler engines of the same family. There is a drain plug on the RH side of the engine, toward the front. Square head pipe plug. They get loose and oil leaks out, and people don't check it, it runs outta oil and bingo, engine failure. Also common are valve cover oil leaks on engines that have sheet metal valve covers. The plastic ones don't leak much if at all. And lastly, the old style ignition coils and starters are high failure items on the Courage V-twins. Kohler has updated all of those and the new stuff is much more robust. All except that stupid drain plug!
That said, you can get a new engine (complete) from Kubota, but they're expensive. They are COMPLETE, you bolt it on and hook up your cable, fuel line, and wirings. It will also come with the updated starter (has a 40% larger shaft plug about 50% more torque as I remember).
Second option-short block. Kubota doesn't sell a shortblock. Kohler does but you will have to do a lot of research to find it. I got one for mine, was $667 at the time. Probably $1200+ now. The bad part is, you will have to remove the engine and take the heads off for inspection before you order a short block. You will be reusing the heads, intake, gov linkage, choke/throttle plate assembly, engine electrical, flywheel, blower housings, and all of the exhaust. If the heads are damaged, you'll probably be better to replace the engine assembly. The part number I used was Kohler 32 522 06
Or last option. Find yourself a kawasaki engine and bolt it on. I think the muffler from the Kohler will fit. The biggest issue will be the throttle cable(s) and then possibly the wiring harness. I want one on mine and had 3 of them to "try" but they all went in the scrap dumpster before I could nab one.
