Zero Turn Mower Comparison
kaxel
Erie
We are currently in the market for a 54" Zero Turn Mower. We are looking at two models. ZG127S-54 and Z125SKH-54. We have gone through the brochures quite extensively and cannot determine the difference between the two. Can anyone offer assistance? Thanks!
virginiavenom
373
Sherman, TX
just a guess here, but it seems the 27 and 25 in your model numbers dictates engine HP. so an additional 2 hp would be the start.
the Z and ZG are different in and of themselves. ZG is the next level above Z. probably heavier, stronger
S vs SKH is the next questions.
looks like a few. weight. about 500 lbs on the higher one. faster going forward and backward, the ZG is shaft driven instead of belt, has a wet disc clutch (stronger) over a dry disc clutch. mechanical lift vs the hydraulic lift on the ZG (deck) see through smaller fuel tank vs electric fuel gauge larger fuel tank on the ZG
there is many differences that I can see at just a glance. ask to ride both at your local dealer, the differences should be noticeable.
UnionMan
M5-111HDC12, L3800 HST , RTV-X1100C, SCAG TigerCat 61" Kawi FX Motor
Aug 21, 2013
104
Warrenton, VA
I think the KH stands for the Kohler power plant models. I was looking at the Z725KH-60 series myself last fall and saw that they all came with Kohler motors but just recently Kubota came out with the Z725X-60 which has the Kawasaki motor. Could be the same thing in the Z1 series. It could designate what power plant comes with it.
UnionMan
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
Any ZT that uses a 28 hp EFI kohler is great. It has been the best motor I have ever had, on any mower, in my 25 years experience, in the biz... Mine is on a Dixie Chopper, which has also been a good buy...:D
6,283
We've got a Grasshopper with a 29HP Kubota. You don't wear them out you just trade for other features. Sure is nice to have a power lift deck. Simple to clean or sharpen/change blades.
