At a tad over 10 hours, so I greased the FEL points on the B2601.
One of the zerks behind the "swift tach" label is loose. I have not had to mess with zerks in absolutely eons. Should I try turning it the approximately little more than 3/4 turn to get it in the right location? Can I take it out and put a washer under the wrench flats? I greased it by turning it to straight down, but it wants at least another 1/4 turn to be tight, and then you cannot get the grease gun onto it. Maybe some teflon tape will make it tighten up almost where it is?
Have to lift the FEL to not stand on ones head to grease these 2 zerks.
