ZD331 not starting
mak252
Trenton, Illinois
Hello, I am having an issue with my ZD331. My father used it yesterday. He shut it down to out fuel in it. He went to start it back up and nothing. I have checked the pedal switch, arm switches, pto switch. I have checked the ignition switch and get continuity on all of the post but the accessory post. Could this be the issue? If not anyone has any idea, that would be great. thank you.
kuboman
721
When you say checked the switches, how? You need to bypass each switch to remove it from the system to really know if it is the problem.
mak252
Trenton, Illinois
I pulled the switches off, checked them with the continuity tester, and they all passed. I tried to jump the starter, but it wouldn't turn. However, I had the starter tested and it passed. Thanks!
8,832
If you tried jumping the larger battery terminal on the starter to the small spade terminal on the starter and It won't turn and you are 100% sure the starter is good then you have a bad battery or bad battery cables or connections.
