ZD326 won't crank
johns6
zd 326
Oct 3, 2013
round top texas
My zd326 overheated today and the alarm went off. After shutting it down to cool off it now won't crank. My gauge lights work, but there is not any kind of clicking sound at the starter. Thanks for any help, first post here.
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
Check your safety switches, your starter may be locked out.
You can bypass to test........trigger on solenoid to battery.
richarddale
Zd326 m9000
May 16, 2016
London Kentucky
my zd326 is doing the same thing will not crank with key cross the senolid it starts but will not shut off with key any one know what could be problem ??
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
I don't have your wiring diagram but I'm guessing it will be like many others, I believe there is a "combination switch" (brains/relay box) under the seat somewhere, with a dozen or so wires coming from it. The starter and the shut off solenoid will be controlled from there, disconnect the wiring connectors to it and re-seat them and see how you go. All the inputs form the safety switches from both levers/PTO/Seat switch/Park brake also go to it. Also check each wire is pushed onto the fuse connecters properly as they have a habit of vibrating loose, as well as the ones on the back of the key switch. Also if the ground wire from this "combination switch" is loose it will create similar problems, so if you can, follow the Black wire to a ground point and ensure it is tight.
richarddale
Zd326 m9000
May 16, 2016
London Kentucky
Thanks for the info that is where i was starting to think the problem is. Will check that out closer, do those boxes go bad very often. will let you know what I find and thanks again.
EEK
ZD326, MX5200
Jul 20, 2017
Bryan, TX USA
I have an issue with the safety switches - I had been mowing for several hours and the engine started to cut out. It rapidly got worse and finally quit. It appears it is safety switch related. With key switch in on position The lights on the dash are off (all items in correct safety position), however I can "rock" in the seat and the dash lights briefly come on. I checked the seat safety switch and it appears to be working properly. Any ideas on where to start trouble shooting? Thanks in advance for your help.
