Zd323 help
tpaul71
Zd323
Aug 2, 2022
Ga
I’m looking for glow plug adapter to check the compression on my mower. I’ve seen where i5 is a 8mmx1 but also seen it’s a 10.25 mm x1. whichever it is where would it be available?
tpaul71
Zd323
Aug 2, 2022
Ga
Are you sure it’s not a 10 x 1.25? If that is what you need then https://www.toolsource.com/engine-s...iesel-adapter-glow-plug-10-x-125-p-93009.html
I’ve seen that size and also saw 8mmx1 but I’m not sure which is for glow plug
Curious about why you feel the need to check compression?
How many hours are on the unit?
dave
dave
was cutting grass and it blew puff of smoke out shut off and won’t start back up. Sounds lIke it has noise coming from intake when trying to start. Sounds like squeaky horn best I can describe. Unit has around 800 hrs
Captain13
Feb 27, 2019
520
170
Kathleen, GA
You can pull a glow plug and take ir at a NAPA store. They usually stock glow plugs and can pull up on their computer what the specs are for the plug including thread size.
