ZD28
Debaglio
zd28
May 12, 2022
12
Maryland
I need a little advice. I have a ZD28 with slightly less than 1000 hours. Approximately a year ago when I would try to start it would click a few times and then start. I thought it was the starter selenoid and replaced it over the winter. So far this year it was good. The other day I went to start it and all the lights worked, but it wouldn't even click. I worked on it today, cleaned out the grass and stuff underneath, thinking perhaps it was a safety switch. After cleaning, it started right up. It started 8-10 times, no issues. Put it back together and went to start and it clicked several times and then started. Question is, could it be the starter? Any suggestions would be greatly appreciated.
Workerbee
Zd21
Mar 1, 2020
308
165
MN
Id clean and tighten a bit the wire connections that go onto the starter solenoid. Theyre usually spade terminals. Thats cured the same issue for me on other machines.
DONLI
L3301,FL, MUSTANG 2054 SKID STEER, 6FT HYD. SNOW BLOWER,and other things of labo
Jul 28, 2025
23
17
duluth mn
Ck the Battery sounds to melike a battery.
My zero turn did the same thing and a new battery fixed it!
Don
Hugo Habicht
G1900
Jun 24, 2024
644
852
Ireland
The clicking is the solenoid moving the pinion into the flywheel.
Simultaneously it closes a contact for the rotor current to flow (fat cable from battery). When it is clicking and starter not moving it can be that those contacts are burnt. Alternatively the brushes for the starter rotor could be worn.
Other than that there is only the cables from the battery (also ground wire!) that you said you checked already. Or the battery itself. You may put a voltmeter from battery minus to the fat starter plus cable and check voltage while starting. A new battery can be dead too (unfortunately).
Is there any adjustment on the solenoid? In this case maybe it is not pushing the pinion far enough for the contact to close.
Debaglio
zd28
May 12, 2022
12
Maryland
Multiple responses:
I will check the cables when I get back to the mower in a a day or two.
I do not believe there is an adjustment on the solenoid, but cannot say for certain.
Thanks for the suggestions and ideas.
Hugo Habicht
G1900
Jun 24, 2024
644
852
Ireland
Typically there isn't.
Check the voltage while starting, this rules out battery, cables, connections.
If voltage good I would check the high current contact. If those are in the solenoid they should be good, because you replaced that (picture of starter would help). That leaves the brushes. Or windings themselves.
Wrt the contact: it burns off when releasing the start key, the stored energy causes a spark. So the contact opening last burns off even more, the gap getting bigger. In most faulty starter cases I had it was sufficient just to turn the moving contact part by 180 degrees and cleaning the contacts a bit.
Hugo Habicht
G1900
Jun 24, 2024
644
852
Ireland
Ok, got the starter drawing:
The contact is in the solenoid, you changed that, so contact should be fine. Should, not must :giggle:
Check the voltage between battery minus and the plus contact (orange arrow) when starting. If this is good check voltage between battery minus and behind contact (green arrow).
If voltage is good in both cases the brushes are behind the cover (blue arrow).
Do you have a work shop manual? This outlines detailed testing and repair procedures the starter.
Hugo Habicht
G1900
Jun 24, 2024
644
852
Ireland
That is the inside of the starter. In cannot see any adjustment on the solenoid. Nuts for cables tightened correctly?
