Zd21
n8300n
ZD21
Jun 12, 2010
Harvard, IL
I have a ZD21. It has not given me that first bit of trouble until three days ago. It will not start. I changed the filters, pumped fuel all the way through the filters and line to the injectors then started it up. I ran it for two hours then it quit. Any suggestions?
KubotaTech
None- I get to play with everyone elses stuff
Apr 1, 2010
185
PA
When it shut off, was the fuel pump still pumping? I assume it cranks but does not start. With the key in the on position, you should be able to hear the fuel pump pumping and see fuel in the filters. Any smoke while cranking?
n8300n
ZD21
Jun 12, 2010
Harvard, IL
Pump works fine. I used air to blow out the lower filter and the fuel line leading back to the fuel tank. The ZD21 runs like new again.
I can't imagine what is in the tank pluging the fuel line. :)
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,140
139
Hardisty, Alberta
It'll likely show up again. I had a bug in the fuel tank on a BX2350 a couple of weeks ago. How do you put a warranty claim through on that? LOL
ED
