What happens if the blades are not engaged? Gas or Diesel engine? Is the radiator clogged on outside or inside? Does it die a slow death or like there is a switch turned off? What happens if you disengage the blades while it is dying?
I could keep this up for awhile but it would probably be better if you could describe the problem in greater depth.
Right now the answer is put fuel in and restart.
