I have a new X1100C,will not crank when warm.If it sits a cople of hours,it works fine.Seems like a neutral switch problem.Can someone tell me where the neutral switch is?I don't see it on the transmission.
Wont crank or wont fire? Just want to clairfy. Neutral is a position of the shift lever. Also be sure the hydraulic lift cylinder lever is in neutral. See manual pg 67.
The Range shift safety switch on an RTV-X1100C is on the LH side of the transaxle assembly a few inches forward of the rear axle, about halfway up. I seriously doubt that is your problem.
