would like to ad a auger to my L345D
rexbarker
l345D 1720 loader
Oct 10, 2020
Friday Harbor, Wa
I have installed a quick tach on my loader.Would like to know if I have the hydraulic capacity to run a cat A23 auger? also what else do I need to ad to spin the auger bit.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,226
1,011
Williamstown Ontario Canada
The answer is a qualified yes if you buy the Kubota/Landpride unit designed for low flow tractor systems.SA20
The spec's for your tractor say 6.4 gpm.
Sometimes, on older machines this number is misleading if you have power steering as the PS flow is included in the total hydraulic flow.
Watch this video on the SA20..
Post Hole auger
Unless you have a lot of holes to drill, hiring someone to do the work makes more sense $ wise as getting into hydraulic systems complete with third function valve quickly gets expensive when making these systems work on older tractors.
Dave
BigG
Sep 14, 2018
1,951
769
West Central,FL
The Cat auger requires to much oil. This is more like what you need but the requirements may still be to high for your tractor. Contact them and see if it will work. Come back with what you learn and share.
NHSleddog
B2650
Dec 19, 2019
2,149
1,830
Southern, NH
My B2650 has 5.0 at the 3rd function. While it isn't magic (there are rocks and obstacles that will stop it) it is a fantastic setup. I have easily done over 1000 holes with it at this point.
I went with the AugerTorque brand because it is better suited to low flow applications.
I also modified a cement mixer bowl that I mount to the auger to mix cement.
