I just purchased a Woods SB64S Snowblower and having trouble connecting. I either need to shorten PTO Shaft or extend 3 point harness to connect.
Does anyone have this set up?
It's not uncommon to have to shorten a PTO shaft. Make sure you measure the shortest distance between output shaft on tractor and input shaft on snow blower. Too long of a shaft can damage the tractor or implement.
Mike watch this and do as they are telling you take the measurements because if its too long like dts said you will BRAKE sumthin never a cheap or easy fix so watch and learn
