Woods/Kubota subframe difference between B3030 and B2920
walrus
B2920
Dec 8, 2024
Maine
Just bought a used 2008 B2920 thinking of trying to find backhoe for it. Found used subframe for 2008 B3030, They used same backhoe
from factory. I think its a B64?
My question is this 3030 frame the same as one for a 2920?
5,042
goto Kubota's parts webpage and lookup the two units, compare part numbers for major components of the subframes. if the numbers match, I 'think' it's fit.
6,594
They didn't use the same BH:
The subframes attach in a similar manner but I don't know if they are dimensionally the same size.
walrus
B2920
Dec 8, 2024
Maine
The ad says the backhoe was a BH 65 on the 3030 but I saw the same thing you did when looking at attachments for the 2920 and the 3030. I see Kubota backhoes that have been converted to just attach to 3 point hitch but haven't found a BH 65 yet. I probably could do the same with one of those backhoes but I'd think the subframe would be better. The pieces on market place are significantly cheaper than new. Go figure :) The frame pieces for the 2920 are a different part number than the frame pieces for the 3030, I appreciate the help, thanks
