Won't start.
Alex from GA
L175
Mar 27, 2013
20
Gainesville, GA
I had a thread last week about an L175 that I ran out of fuel and couldn't get it started. I bled the fuel system 3 times, installed new glow plugs and a new battery. Still won't start. Won't hit a lick.
Busy fishing all week so got on it today, Saturday. Installed the new glow plugs, got a new battery installed and it didn't hit a lick. Bled the fuel system again for the 4th time and nothing. The indicator on the glow plugs glows again so they're working. Put a jumper on the battery and it spun great but still doesn't start. I've had the tractor for 18 years and this is the first time I've had a problem I couldn't solve. The last two times I've ran out of fuel it started after a while.
3,014
When you bled the system.......... good amount of fuel come out of bleed valve?
Pau7220
Aug 1, 2017
785
280
Scranton, PA
There are diagnostic procedures you need to follow. You stated in your previous post that you used starting fluid, and dumped fuel into the cylinders…. There’s a very good probability you either bent connecting rods or broke your ring lands... the damage will happen immediately. You definitely need to do a compression test on that engine, which will give you an answer on engine condition and determine your next step. ”Blew my finger off the injector holes” is not a compression test.
Roadworthy
L2501 HST
Aug 17, 2019
1,647
529
Benton City, WA
I like to make sure the dumb stuff is done first. The last time I had a tractor not start I tried several things before checking the air filter. i cleaned it and the unit fired right up.
