I have an old L175 that I ran out of fuel yesterday. I opened the bleed nut and cranked it and never got any fuel out. I squirted in some ether, with oil, into the intake and got a couple of bumps but it wouldn't start. Mosquitos were eating me up so I left it until morning. In the morning the glow plugs aren't working so I hot wired them for 20 seconds and tried it again for naught. Squirted WD40 and it burped a couple of times. Took the fuel lines loose and cranked until it was wet, put it back and still no start. Took the fuel lines off and cranked until fuel was coming out of the pump in spurts; put it back together and still no start. Removed the injectors, cleaned and blew down the holes; put it back together and still no start. Couldn't leave it out in the street so I removed the bushhog and towed it home. How do I get the damn thing to start please. BTW I took the filter off, emptied it and blew it out, and refilled it. It ran fine for the past few months after I had the clutch freed from non use for a couple of years.
First of all, don't use starting fluid to try to get your engine going. It's a good way to break piston rings and damage the engine. I'm going to assume that you have full fuel flow from the tank to the fuel filter. If you don't, you'll have to make sure you do. t will not start if the tank outlet or hose is blocked.
You need to bleed the entire fuel delivery system after you run it out of fuel. Do you have an owner's manual? If you don't, try to find one because it will have specific instructions for your tractor.
Here's some general instructions that may help you. First of all, make sure the battery is fully charged because you'll be doing some cranking UNLESS you have a primer pump. Fill the tank with fresh fuel. Replace the fuel filter. (You can't "blow out" a fuel filter. You'll most likely damage the element.)
If it has a tank valve open it and open the bleeder screw on the top of the fuel filter. Crank the engine until no bubbles and just fuel comes out of the bleeder screw. Crank in 15 second bursts. When just fuel runs out of the fuel filter breather, screw it closed.
If you have a bleeder screw on the injector pump, open it up and do the same thing. Crank until the only fuel comes out of the bleeder, then close the bleeder.
Now go to the nut that attaches the fuel line to an injector. Unscrew the nut, but do not take it off. Crank the engine in sort bursts until nothing but fuel is evident at the nut. Repeat on the other injectors until the engine starts. As an alternative, you can loosen all the injector lines connections and crank until no bubbles of air are evident. Then tighten them down and crank to start.
