Wiper wiring
Scout7760
Reading Michigan usa
I have a 2018 Kubota 1120D. I just put a windshield wiper on and can not find or figure out where to hook the red wire and black wire too. The dealer took me there are wired under the hood on driver side. I have search over and over and can not find a red and black wire. Please help
mikester
M59 TLB
Oct 21, 2017
3,882
2,532
www.divergentstuff.ca
I am assuming you have a factory cab. Usually there is an existing OEM wiring harness you can tap into.
If you dont have an existing wiring harness available then start from your fuse panel, use an appropriate circuit and run a suitable sized fused power lead (RED) to your wiper motor. You can also choose to run a BLACK ground wire to an appropriate ground or ground it to the chassis somewhere near the wiper motor.
Your operators manual should have a wiring diagram along with color codes.
