will not drive
ron c
ashburnham ma
Need help, I have b7500 with hst/transmision engine that runs but wont drive. The rear pto won't operate and there is a grinding noise when pressing the clutch in. The front end loader work fine. Any suggestions on what the issue may be? Thank you
Kytim
Aug 14, 2009
848
12
Western Ky
ouch! well is it cracked enough to be out of line? did the clutch "explode" or in other words tear the lining off when tractor was in a strain and the crack occured?
you know the whole torque tube could be flexing while straining with the pedal movement? thus misalignment causing noise. I've seen those housing welded up before, i've got one now but all must be repaired, including clutch before being welded and reinforced. a simple bead may not be enough to prevent further breakage.
kytim
