Wider stance for 3901
1,549
There are a few rear wheel variants for that tractor. One version does allow the rim and tire to be mounted in different positions on the center disk. If you can see some bolts holding the rim to the disk then yes is the answer
7,447
Can I change rear hubs around for a wider stance on a 2021 3901 HST ? (Ag Tires filled with Rim Guard)
You don't change the hubs, just the rim centers and rings.
And you do not change the front wheels.
