widening a snow blower
Stomper
2017 L2501. Landpride Mower. Farm King Snow Blower. DIY Root Bucket grapple.
Jun 30, 2017
240
Northern Canada
I wasn't sure if I should put this here or the snow removal section. Being it's an attachment question, I put it here. Throughout the winter I have been using my FEL for plowing and moving snow instead of my PTO blower because I can move more snow faster. Average snows here are usually less than 5" so the FEL works better. Having said that we have gotten a lot of snow this year and now I have huge 6' piles of snow all over that I would like to blow further into the bush before it starts to warm up and melt. I gave the blower a try today for this and it moves a lot of snow and will work great. I was surprised that it cut right through the hard pile with ease. Problem is, my tractor width is 60" and my blower width is only 50". As soon as my tires hit the 5" per side that the blower didn't get, I start to spin. Has anyone tried to add "wings" or something to widen the blower and help direct the snow towards the auger to help solve this problem.
8,173
A lot of three point blowers come with wings, I have them on mine.
Depending on the model they either make a set of factory wings or you could make them yourself.
Stomper
Jun 30, 2017
240
Northern Canada
Looks easy enough to build. Does the widening cause any issues in hard packed snow, being that they are cutting the hard packed snow several inches before the auger.
8,173
Yea they are a little tougher to use with hard pack.
But if they are built heavy enough and you've got enough tractor pushing them they work. ;)
200mph
Mar 3, 2017
1,228
61
PA
Stomper,
I made a set of wings for my 72" blower and documented the build here: http://www.tractorbynet.com/forums/kubota-owning-operating/390742-snowblower-wings-homemade.html
To gain 5" per side, the 6" wide piece used in my build would need to be replaced with something wider. Assuming piece is at 45 degrees, 7" = 4.95" additional width and 8" would yield 5.66" per side.
These have been great snow insurance. Since fabricating and installing no meaningful snow fall has occurred, so can't comment on their effectiveness.
Stomper
Jun 30, 2017
240
Northern Canada
Stomper,
Thanks 200mph, Great work. Looks real easy to build. Guess Ill have to get at it.
Thanks again
200mph
Mar 3, 2017
1,228
61
PA
Stomper,
Finally received some snow over the weekend. It was only 6" and very wet, but I'm happy to report the wings worked well with no negative side effects. Even the rubber worked in keeping the road clear.
Granted this wasn't much of a test, but at least it is a data point.
The wings definitely helped in finessing the blower under the mailbox, around garage doors or other obstacles without the rear tires getting in the way.
The wings were made from 1/4" bar, which matched the thickness of the blower housing.
Stomper
Jun 30, 2017
240
Northern Canada
Great to hear. I haven't built mine yet but it's still on my build list. It's a long list
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,252
1,031
Williamstown Ontario Canada
Stomper,
Assuming you bolted the wings on, suggest you use lowest grade smallest bolts so when you hook a wing on something, which I have done, the bolts shear and you don't damage whatever you hit.
If you are young with a flexible neck, disregard!
Dave
