Why won't my tractor start???
Bigbutch67
GST 4630 w/hoe
Apr 14, 2016
Hegins, PA.
I have a B4630, GST, bought it used, about 2 yrs ago. Ran fine. Yesterday went to dig hole for friend, everything went great. When leaving, they wanted to talk to me, and since I'm getting hard of hearing, I had to shut the machine down. Was running perfect until then. Battery is fine, but no dash lights come on, won't turn over, and don't get any click from switch when key is turned. Does anyone have any Ideas??? Being retired and on fixed income, I'd rather try and fix it myself, if possible! HELP please!!! Thanks
dfh1977
198
east ky
Just as guess but check to make sure everything is in correct place. Something simple could be preventing it starting.
CountryBumkin
Sep 27, 2015
568
Central FL
If nothing electrical is turning on - my first check would be the battery cables. Is one loose or corroded?
3,073
All you need is a safety switch to be .1" out of whack.....
wiggle the seat as you sit, wiggle the pto lever, the clutch .....
betcha a cold one - a switch aint sitting jussttttt right.:D:)
CountryBumkin
Sep 27, 2015
568
Central FL
But dash lights would still come on.
hodge
Nov 19, 2010
2,963
531
Love, VA
Welcome!
Cheapest, simplest, most common, and the first place to check- the cables. Both on the battery, and at the other ends. Then, start looking at safety switches, as mentioned.
11,167
Being a GST, move the shuttle lever back and forth to neutral. ;)
