I have an D1803 engine from a L3400 with a big hole in cylinder wall #3. The connecting rod is bent and the piston is really destroyed. Two push rods are also bent. No visible damage to the head. The crank does not appear damaged at all. The other two cylinders appear normal. The oil does not appear to have water. Head gasket appears intact. I am in process of taking the engine apart.
Without knowing the cause for the bent rod, I am concerned that I may not fix the root cause of the problem. I will have the crank tested and will replace the one rod and all pistons and bearings. What else should I test to determine the cause for the bent rod? If water got into the engine, wouldn't it be evident in all cylinders? Can a bad injector be the culprit?
Pics Attached
Pics Attached
